script runner - Set field description not working for Insight field
Nagaraju October 18, 2022
Hi Team,
Recently I written a script to set field description as linked issues when selected issue from issue picker(Script runner issue picket field) but due to permission issue we are planning to change script runner picker field to JIRA insight field, but the same code not working for insight field.
Code:
import com.atlassian.jira.config.properties.APKeys
import com.atlassian.jira.issue.customfields.option.LazyLoadedOption
import com.onresolve.jira.groovy.user.FieldBehaviours
import com.onresolve.jira.groovy.user.FormField
import groovy.transform.BaseScript
import groovy.transform.Field
import org.apache.log4j.Level
import org.apache.log4j.Logger
import com.atlassian.jira.issue.link.IssueLink;
import groovy.xml.MarkupBuilder
import java.sql.Timestamp
@BaseScript FieldBehaviours fieldBehaviours
@field ApplicationUser loggedInUser = ComponentAccessor.jiraAuthenticationContext.loggedInUser
def issueManager = ComponentAccessor.issueManager
def issueLinkManager = ComponentAccessor.issueLinkManager
// Related issue field name
final issueKey = getFieldById("customfield_38711");
// Relates issuelike
final issueLinkTypeName = 'Relates'
// Get the issue
def issue = issueManager.getIssueByCurrentKey(issueKey.getValue() as String)
def hIssueUrl = new StringBuffer()
def tableAppender = new StringBuffer()
def linkedIssuesHtmlLinks = filteredLinks.collect { issueLink ->
def issueUrl = "${baseUrl}/plugins/servlet/desk/portal/22/${issueLink.destinationObject.key}"
//Set field description
hIssueUrl.append("<br><a href='${issueUrl}'>${issueLink.destinationObject.key} - ${issueLink.destinationObject.summary} - ${issueLink.destinationObject.description} - ${(issueLink.destinationObject.status.getName().toString())} </a>")
issueKey.setDescription("Selected OCM Issue Feedback"+hIssueUrl)
Max Lim _Adaptavist_
October 20, 2022
The problem is that, since you are retrieving a value from an Insight field, you are getting an insight key, instead of an issue key.
So, you need to replace:
 with something like:
import com.onresolve.scriptrunner.runner.customisers.WithPlugin
import com.riadalabs.jira.plugins.insight.channel.external.api.facade.ObjectFacade
@WithPlugin("com.riadalabs.jira.plugins.insight") def objectFacade = ComponentAccessor.getOSGiComponentInstanceOfType(ObjectFacade)
def insightObjectKey = getFieldById("customfield_38711").getValue() as String
// This should returns "OCM-3800 - Listing & Calendar Settings - Air Agile Calendar" def insightObjectLabel = objectFacade.loadObjectBean(insightObjectKey)?.label
def issueKey = (insightObjectLabel =~ /[A-Z]+-\d+/)[0]
def issue = issueManager.getIssueByCurrentKey(issueKey)
The snippet comes from this insight script documentation. Then, I improve it with our WithPlugin annotation to load autocomplete for classes when writing script. You can read more about ObjectFacade in its javadoc. Lastly, the "=~" is Groovy's find operator that match a substring using regex expression, which is documented here.
I hope this helps.
Nagaraju October 20, 2022
Hey @Max Lim _Adaptavist_ , Thanks for your help, it is working fine now.
-Musku
Olly von Fay-Siebenburgen _ScriptRunner_
Hi!
Olly here from Adaptavist Support!
May I ask, what version of ScriptRunner and Jira are you using?
Hope to hear from you soon!
Olly
Nagaraju October 19, 2022
HI @Olly von Fay-Siebenburgen _ScriptRunner_ , Thanks for your reply,
I am using JIRA Data/Center 8.20.11 and ScriptRunner 6.58.1
