🪄 Automate your Confluence documentation
The automation team recently released a new trigger: Project created. Which made me think: what if we could automatically create a new Confluence space when a new Jira project is created? It would save us a lot of time and ensure we always have a Confluence space associated to a Jira project. Let's do it!
🔎 Gather your API information
We will use Confluence Cloud API to automatically create a new space. Go here to create a new API token:
Save the generated token in a safe place.
🚧 Build the rule
Select the Project created trigger:
You can restrict the trigger to a specific project type - you may want the Confluence space to be created only for Software projects.
Then add a Send web request action. This can be a bit complicated, let me break it down for you:
  • Webhook URL:
https://yoursitename.atlassian.net/wiki/rest/api/space
  • Header:
    • Name: Authorization
    • Value: Basic followed by "email:apitoken" encoded in base64
Go to base64encode.org to generate your header value. Just type email:apitoken and hit encode. If my email is manon@gmail.com and my API token is 12345, here is how it should look like:
  • HTTP method: POST
  • Webhook body: Custom data
"key": "{{project.key}}",
"name": "{{project.name}}",
"description": {
"plain": {
"value": "This space is linked to Jira project {{project.key}}.",
"representation": "plain"}
We are using a bunch of smart values in the custom data so that, in both our new Jira project and new Confluence space, we have the same key and name. Read more here about smart values you can use.
Almost there! Here is the final Send web request action:
🚨 Improve your audit log
This is optional but I like to add log actions. It will come in handy if you need to debug your rule:
You can use the following smart values:
{{webhookResponse.status}}
Space {{webhookResponse.body.key}} successfully created
Uh oh, something went wrong. Error {{webhook.Response.status}}
Note: if you do add these actions, remember to enable "Delay execution of subsequent rule actions until we've received a response for this webhook" in the Send web request action.
â›± Sit back and relax
You did it! A new Confluence space will now be automatically created whenever you create a new Jira project:
5 comments
Alexis Robert August 7, 2021
Great use of the Confluence API to automate Space creation ! Thanks @Manon Soubies-Camy
Like • Manon Soubies-Camy likes this
Jack Brickey
@Manon Soubies-Camy , another awesome use of automation. Thanks for sharing.
Like • 2 people like this
Alex Koxaras -Relational-
Very useful automation! This will come in handy! Great work @Manon Soubies-Camy!
d.kirsching
Hi @Manon Soubies-Camy
Great work and helpful article ! Thx.
However, seems to be basic authentication is now deprecated in cloud.
Link doesn't work and I can't find the right article. Anyone have it ?
Thx,
E Hanumanthu September 9, 2022
Will the same configuration works in Data center as well? Can you please let me know.
Register today
