Convert HTML to Jira WikiMarkup
While Atlassian made some workaround ways to convert Jira WikiMarkup to HTML.
There is no way to do the other way around and convert HTML to Jira WikiMarkup.
I saw all over the community, a lot of people looking for a way of doing it.
So i decided to create packages for any environment people asked me:
Nuget package for .Net : https://www.nuget.org/packages/Html2JiraMarkup/
npm package for JS: https://www.npmjs.com/package/html-2-jira-markup
Hope it will be useful for many other people.
You are welcome to say thanks or ask for package to another language / framework and i will try to do my best.
19 comments
Anandraj Rajaram November 30, 2021 edited
@Nir Haimov  can you share any libraries for Java. To Convert Html to Jira Markup?
Nir Haimov
Hi @Anandraj Rajaram
I will try to find some free time and create library for Java too.
i will update with link once i'm done
Thanks @Nir Haimov .
Nir Haimov
Sorry for keeping you waiting for nothing.
Eventually, i will not create a Java library, i tried to, but found myself too long around it, so decided to let it go.
You can however look at the implementation i did in one of the exiting packages, and try to do the same in Java
Anandraj Rajaram January 7, 2022
Thanks, @Nir Haimov . I got this library from Atlassian
<dependency>
<groupId>com.atlassian.renderer</groupId>
<artifactId>atlassian-renderer</artifactId>
<version>8.0.5</version>
</dependency>
 and temporarily solved with the below method
convertXHtmlToWikiMarkup
but just got few minor issues like the above method is not converting <BIG> html tags
Andrew Hines (!)
January 7, 2022
Hi Nir - This is great. I'm looking for exactly this - but in PowerShell (!)
Is that easy to provide ? If so would you be kind enough ??
Thanks ;) Andy
Nir Haimov
Hi @Andrew Hines (!)
Sorry, but i'm not familiar with PowerShell
siddhesh pawar February 9, 2022
Hi @Anandraj Rajaram ,
can you please guide me how you resolved this issue?
where you added the library?
<dependency>
</dependency>
and where and how you used below method?
Fabio Silva March 10, 2022
Hello, @Nir Haimov  In one of your answers in this thread you said  "You can however look at the implementation i did in one of the exiting packages, and try to do the same in Java".
Is this open source? If yes, can you provide repository links? I am interested in C# sources.
Thank you
Nir Haimov
Hi @Fabio Silva
This is not exactly an open-source.
What I meant is, if you use one of my packages you can view the package content with your IDE (like visual studio)
Anyway, I made a package for C# https://www.nuget.org/packages/Html2JiraMarkup/
RS May 9, 2022
Hi @Nir Haimov ,
If we have table tags in html string its not getting recognised in jira, its just printing table as is. Any known bug ?
Michael.Leibovitch2
August 19, 2022
Hi @Nir Haimov
I tried to use Html2JiraMarkup on C# and the return value was the same as the HTML original value.
Am I missing something?
Michael.
Nir Haimov
Hi @Michael.Leibovitch2
Please share the HTML string you are trying to convert and your code where you tried to use it
Suzanna Bryon
October 6, 2022 edited
@Nir Haimov I used Html2JiraMarkup, but it didn't convert fully. Is that how it is designed to work?
Nir Haimov
Hi @Suzanna Bryon
Yes, It might not fully convert exactly as expected
Like 2 people like this
shrikant maheshwari
@Nir Haimov
Hi Nir,
Is there any package available for NODE JS ?
Manoj Channa March 9, 2023
https://www.npmjs.com/package/html-2-jira-markup JS package did not do a good job for converting HTMLs. So did not use in our case.
Like cmilner likes this
Eruvavenkata Lingareddy --CNTR
January 9, 2024
Hi Nir Haimov
Good day.
I also have a same requirement, Is there any JavaScript library to convert html tags into Jira Wiki Markup language to use it in my SAPUI application ?
Regards, Venkat.
Like Lia Mack likes this
Quang Trí
April 4, 2025
Can help me
How to convert Jira's wiki markup to HTML
Register today
