There are various reasons why we might need to change out schemes for a project. The following information applies to Jira Cloud Company-managed projects (CMP).
The Scenarios
Default Schemes
Perhaps we are using a default scheme and need to have something more tailored for our project. These are probably the simplest scenarios - when the project is using the Default Notification Scheme or Default Permission Scheme that comes with your Jira site.
While they are a good start for most projects, you often need to tweak them for some of your projects. We can’t just update the default scheme with the project specific information. We need to create a new scheme and replace the one that is there. The same might also be true for Field Configuration Scheme.
Shared Configurations
Another common scenario is when we have multiple projects using the same scheme, and one project needs to make a change. If we update the shared scheme, it will change for all projects. So, again, we need to create a new scheme.
Switching Out Schemes
Most of the schemes are switched following the same procedure. The exception would be the Workflow Scheme, which we will discuss last.
To change the schemes, you must be a Jira Administrator.
While on a project, click on Project Settings. You most likely will land on the Project Details page. At this point, you could click on the appropriate related link on the left-hand menu, such as Permissions; however, I like to go directly to the Summary view in the project settings.
The reason I like to start here for almost all of my project configurations is because many schemes are available in one view.
To make a change, simply click on the name of the Scheme. For this first example, we will use the Issue Type Scheme. Clicking on the scheme name will show detailed information about the scheme. Click on the Actions menu on the upper right and select Use a different scheme.
On the following screen, select a new scheme from the dropdown (they should be in alphabetical order) and then click OK.
For the most part, all schemes except the Workflow Scheme will follow this same pattern. You will be done with the switch for most schemes at this point.
Exceptions
If you are on the Free subscription plan for your Jira instance, you will not be able to change the Permission Scheme.
If you change the Issue Type Scheme and the new scheme does not contain issue types that were available in the previous scheme, you will need to migrate the previous issue types to one of the issue types available in the new scheme.
Workflows
To change the Workflow Scheme, click on the name of the workflow as above. Making the change is much more obvious here as you just need to click the Switch Scheme button.
Like the Issue Type Scheme, if your new Workflow Scheme contains workflows that have different Statuses than the previous workflows, the system will walk you through the migration process from the old statuses to the new statues.
The process as a whole is simple and fairly straightforward. Let me know your thoughts in the Comments below.
John Funk
Jira Business Administrator, Freeosk
ProVision Systems
Kalispell, MT
3,391 accepted answers
Learn more
9 comments
