This guide will provide you with step-by-step instructions that you can use to determine Jira app compatibility in the cloud when migrating from Jira Server or Jira Data Center.
To check app compatibility in Jira you will need to ensure that the Jira Cloud Migration Assistant is installed.
Once you have confirmed that the Jira Cloud Migration Assistant is installed you can navigate to it on the general configuration page.
If you have apps that you need but do not yet exist in the cloud you should:
Once you have ensured compatibility of your apps and identified the apps that will be migrated you can always test the migration of the apps by migrating to a free cloud plan. This is a great way to test how the apps and data will migrate.
Brant Schroeder
Save your spot
2 comments
