×In the previous article I've introduced my ideas and first version of the script for finding duplicate screens in Jira.
Here's the second version with these improvements:
py script.py --url=https://my.testjira.com --user=username --password=password --sortThe last argument has impact on the sorting of tab fields. If you omit it, the tab fields will be left as is, if you add it, the tab fields will be sorted before the comparison. If tab fields are sorted, then the tabs are marked as duplicate if they only have the same set of fields. If they are not sorted, they also need to have the same order.
import time
import requests
import hashlib
import argparse
def get_screens():
start_at = 0
max_results = 100
screens = []
while True:
try:
time.sleep(0.25)
params = {"startAt": start_at, "maxResults": max_results}
headers = {"Accept": "application/json"}
response = requests.get(f"{base_url}/rest/api/2/screens",
headers=headers,
params=params,
auth=(user, password))
response.raise_for_status()
response_data = response.json()
screens.extend(response_data['screens'])
if start_at + max_results >= response_data['total']:
break
start_at += max_results
except requests.exceptions.RequestException as e:
print(f"Failed to get screens. ({e})")
exit(255)
return screens
def get_screen_tabs(screen_id):
try:
time.sleep(0.25)
response = requests.get(f"{base_url}/rest/api/2/screens/{screen_id}/tabs",
headers=headers,
tabs = response.json()
print(f"Failed to get tabs for screen id {screen_id}. ({e})")
exit(255)
return tabs
def get_screen_tab_fields(screen_id, tab_id):
try:
time.sleep(0.25)
response = requests.get(f"{base_url}/rest/api/2/screens/{screen_id}/tabs/{tab_id}/fields",
headers=headers,
fields = response.json()
print(f"Failed to get fields for screen id {screen_id} and tab id {tab_id}. ({e})")
exit(255)
return fields
def get_screen_tab_identifier(screen_id, tab_id):
fields = get_screen_tab_fields(screen_id, tab_id)
fields_list = []
for field in fields:
fields_list.append(field["id"])
if sort:
fields_list.sort()
return hashlib.md5(str(fields_list).encode()).hexdigest()
def get_screen_tab_title(screen_id, screen_name, tab_id, tab_name):
return str(screen_id) + ": " + screen_name + ", " + str(tab_id) + ": " + tab_name
def get_screen_tabs_groups():
screen_tabs_groups = {}
screens = get_screens()
for screen in screens:
screen_id = screen["id"]
screen_name = screen["name"]
tabs = get_screen_tabs(screen_id)
for tab in tabs:
tab_id = tab["id"]
tab_name = tab["name"]
screen_tab_identifier = get_screen_tab_identifier(screen_id, tab_id)
screen_tab_title = get_screen_tab_title(screen_id, screen_name, tab_id, tab_name)
if screen_tab_identifier in screen_tabs_groups.keys():
screen_tabs_groups[screen_tab_identifier].append(screen_tab_title)
else:
screen_tabs_groups[screen_tab_identifier] = [screen_tab_title]
return screen_tabs_groups
def export_screen_tabs_groups(screen_tabs_groups):
filename = "tabs.txt"
with open(filename, 'a') as f:
f.truncate(0)
for screen_tabs_group_key in screen_tabs_groups:
f.write(str(screen_tabs_group_key) + "\n")
for screen_tabs_group_item in screen_tabs_groups[screen_tabs_group_key]:
f.write(str(screen_tabs_group_item) + "\n")
f.write("\n\n")
f.close()
def execute():
screen_tabs_groups = get_screen_tabs_groups()
parser = argparse.ArgumentParser()
parser.add_argument('--url', nargs='?', required=True,
help='https://my.testjira.com')
parser.add_argument('--user', nargs='?', required=True,
help='username')
parser.add_argument('--password', nargs='?', required=True, metavar='password',
help='Password')
parser.add_argument('--sort', action='store_true',
help='Tab fields are sorted before comparison')
args = parser.parse_args()
base_url = args.url
user = args.user
password = args.password
sort = args.sort if args.sort else False
execute()
I have plans to test the script for cloud too and if changes are needed, implement them.
Hana Kučerová
Atlassian Consultant
BiQ Group
Prague, Czech Republic
553 accepted answers
4 comments
