How to run Jira in a docker container
33 comments
Martin Zeller September 2, 2019
@sara you could still use docker swarm to create an overlay network attachable like:
docker network create --driver=overlay --attachable confluence_cluster_net
 and then attach your container to it.
Expose the TC port and set the cluster IPs to 10.0.0.2,10.0.0.3,....
Ravindra Ravindra September 20, 2021
Is there any procedure to upgrade the jira from current version to latest available docker image version?
Like upgrade to major version, for example -
from version 7.6.1 to 8.16.1
Please confirm
thanks
Antoine _Klee Group_
September 27, 2021
@Ravindra Ravindra There is now an official jira-software container available on the Docker Hub have you checked it? If you use a persistant database and jira-home the upgrade is very easy as you just need to call the for the atlassian/jira-software:latest container.
Medhat Ahmed
November 30, 2021
Does installing jira and confluence on docker or kubernetees is officially supported by atlassian? is there a clear documentation from atlassian about that?
November 30, 2021
Hi @Medhat Ahmed as mentionned previously, the Jira Docker container is officially supported by Atlassian. https://hub.docker.com/r/atlassian/jira-software/
I do not know about Kubernetees.
Medhat Ahmed
November 30, 2021
Hi @Antoine _Klee Group_
can I use it for jira datacenter or only jira server?
November 30, 2021
It is actually a data-center image :)
Martin Zeller November 30, 2021
@Medhat Ahmed
here you can find the information about kubernetes https://atlassian.github.io/data-center-helm-charts/
This is a very new documentation, I could not look inside yet.
Would be nice to give feedback here.
Cheers Martin
Help us plant more trees
