Introducing subtasks for breaking down work in next-gen projects
118 comments
Eoin
July 25, 2019 edited
@Becky Klein it's on the backlog but no timeline around it yet. It's definitely the longer term direction we want to go. Thanks
Dennis Christensen July 29, 2019
Can you place a subtask (without the entire task) in a Sprint?
Yi Xu July 29, 2019
Is there a way to reorder subtasks? Drag and drop doesn't seem to do it.
Like Sally Storm likes this
Sally Storm
July 30, 2019
Really looking forward to "Providing more visibility of subtask estimation at the parent issue, on the backlog, and in reporting" and "Estimation roll-up across multiple levels of work hierarchy". Hope to see them added sooner rather than later :D <3
Like 4 people like this
Michał Janicki August 7, 2019
I've noticed that in classic projects, searching for issues belonging to an Epic will return both tasks and sub-tasks. On the other hand, in the next-gen projects, the same will return tasks only. Is this behaviour expected? I'm using Jira Cloud, next-gen project, with sub-tasks enabled.
Like Larry likes this
Also, there appears to be no way to convert from sub-tasks to tasks or vice versa.
Like 2 people like this
Larry
@Michal Janicki, They indicate that the conversion feature is on their roadmap on their write up posting.
Like Michał Janicki likes this
Michał Janicki August 7, 2019 edited
Thanks for pointing out @Larry It's also great to see upward propagation of estimates to be in the works.
There's s few glitches though which have been known and reported for some time now. The ones I'm aware of are
- time tracking not available https://jira.atlassian.com/browse/JSWCLOUD-17447?_ga=2.160742843.76938633.1557308088-2133119942.1532596113
- no way to edit workflow https://jira.atlassian.com/browse/JSWCLOUD-17434?_ga=2.227384093.1618243734.1563276297-2124849326.1531905745
- labels not visible in backlog https://jira.atlassian.com/browse/JSWCLOUD-17450?_ga=2.193466925.1258265852.1565079514-2124849326.1531905745
- REST API not working for epics https://jira.atlassian.com/browse/JSWCLOUD-17305
Also, there is something interesting going on in how the task hierarchy is organised in next-gen.
For epics, when I peek at the epic using REST, its 'subtasks' field is empty. On the other hand, if I do the same for a task or a story, then that same field is populated with a list of sub-tasks. For me, this is causing some interesting behaviour when using Big Gantt - when I import my task board into a program, their system thinks only tasks have sub-tasks, and epics have none.
Also, I seem to have found a workaround for listing tasks with their sub-tasks when using JQL filters. The trick is to include the second Subtasks column in the search results. It's not perfect, because it looks like it's a string field, and as I said this doesn't seem to be an issue in the classic projects (where I find JQL has no problem finding both tasks and sub-tasks assigned to an epic for me), but it's a workaround I can use for now.
Siddhesh Parab
Hi ,
I have used subtask and implemented the same in my project. However, the subtask added is not visible on the board of my project. Is there any setting needs to be changed or simply added to view the subtask on the board.
Sally Storm
August 14, 2019
@Siddhesh Parab I am not 100% sure if this is what you are looking for... but if you are the owner/admin of the board, then when you go to your board, on the right top side there should be a "Group by" drop-down where you can choose Subtask, then they should show in the board.
Like Siddhesh Parab likes this
Siddhesh Parab
@Sally Storm  Thank You for the help. Yes that's exactly what I am looking for , but at same time just wanted to check without using the group down steps as mentioned above , does the subtask are displayed on board directly along with the task once created ?
Brian Cunningham
August 26, 2019
Is there a timeline on the estimation of sub-tasks or tasks? Without providing estimation, there is very little advantage of breaking stories down to sub-tasks level.
JX September 26, 2019
This is the single most important missing piece to my team right now, that would render sub-tasks pretty toothless:
Like you've mentioned, 1 of the core reasons sub-tasks are needed/used is because the task breakdown process provides a better sense of the estimation at the task level. So why wasn't this included in the initial release, and when will it be? This is blocking my team's move to next-gen :(
LarryG
Of particular annoyance to me is that subtasks do not appear along with all the other cards on the board just like any other card.
When viewing them (which currently only admin powers can set), it groups by task so everything is separated vertically. All the tasks without subtasks are at the bottom. The tasks that have subtasks run across the whole line so you can't tell what swim lane the task itself is in.
Partha Gogoi September 30, 2019 edited
Unless I am using some wrong tool -- I don't see something like this....Ideal State of a Roadmap.png
Like Brian Cunningham likes this
Siddhesh Parab
@Partha Gthe above things are visible under Road Map. If you put the cursor on the epic timespan then at the end you can see a dot there is a link symbol .
I dont see the above  happening -- I see more of this....hope I am making sense...:-)
@Siddhesh Parab  -- please check my second post....
@Siddhesh Parab  -- Is there a way to show all SUB Tasks and the dependencies together? Its easier to "EXPORT" the Epics with all the SubTasks showing.......
Siddhesh Parab
@Partha Gare you using JIRA Cloud or Server. I guess the option is available on Cloud. Also try to put the cursor on the date range in to the end you might see the opition
@Siddhesh Parab  -- I am using the current Community Atlassian version -- on this website
Partha Gogoi October 1, 2019
@Siddhesh Parab  -- thanks for your responses earlier -- will try it on the Cloud....
will Portfolio be able to give this layout? Just curious....
Brian Cunningham
October 1, 2019
I am using the cloud version and do not see a breakdown of epics within the Roadmap view which @Partha Gogoi commented on. Looks like they are showcasing a feature they don't have. I don't even have an export feature which is shown in the image.
Siddhesh Parab
@Brian Cunningham the task break down is available under the Board and not under Roadmap. While there are recent updates and under Board, there is a View option on the right-hand side of the window which has two features of viewing the task dependency and progress.
However, quite surprised to know that you can't find the recent updates visible on the board. Are you sure, you are using the JIRA Software on the Cloud and not on the Server?
Siddhesh Parab
@Partha Gogoi I am not sure
