A new navigation for Jira Cloud is on the way! Atlassian is returning to Jira’s navigation roots by replacing the left sidebar menu with a top nav bar. Former Jira Server users will find the design very familiar.
Users are likely to adopt these changes quickly. My colleague, Chris Lutz, who has previously only used the vertical navigation, said the new look is really easy to get used to. He likes that his primary dashboard is easier to find and says “the new experience much more intuitive”.
Here’s a “before and after” comparison so you’re prepared when the change comes to your application.
Compare the numbered areas in the left “before” image to their new location in the right “after” image.
View Comparison Graphic
New Jira Cloud Admin and Personal Settings
Here are some comparison screenshots of commonly used Jira areas.
Click the purple banner at the top to make this page your homepage.
Jira Cloud “Your work” Comparison
View Comparison Graphic | View Before Only | View After Only
Without the blue left nav, there’s more horizontal space to display gadget data. You can favorite dashboards directly in the drop down menu.
Jira Cloud Dashboard Comparison
In the new experience, the recent project colors are muted. You can favorite projects directly in the drop down menu.
Jira Cloud Projects List Comparison
Without the blue left nav, there’s more horizontal space to display issue cards. The grey project sidebar is still present and collapsible.
Jira Cloud Board Comparison
The search feature moved from the left sidebar to the top right of the screen. Click the text box to see items in the drop down. More information fits easily in this space. A column showing the associated project was added to the display.
Jira Cloud Search Comparison
Without the blue left nav, there’s more horizontal space to display columns. The grey “Filters” sidebar is still present and collapsible.
Jira Cloud Search Results Comparison
In the past, the “cog” or “gear” icon was only visible to application and project admins. Now everyone can see it. A “Personal Settings” section is added to the bottom of the menu.
Jira Cloud Settings Comparison
The recent projects list is removed. See recent items on the “Your work” page instead.
Jira Cloud Admin Settings Comparison
Without the blue left nav, there’s more horizontal space to display project configuration details. The grey project settings sidebar is still present and collapsible.
Jira Cloud Project Admin Comparison
Admins can access the admin pages with one less click. Without the blue left nav, there’s more horizontal space to display admin data. The grey admin sidebar is still present and collapsible.
Jira Cloud New Navigation Announcement
When your Jira Cloud application receives the new navigation, you’ll see an announcement overlay, similar to the one above. Users have the ability to use the new nav right away or delay it for later. If you opt to use the new nav, an on-screen wizard will guide you through the changes.
I recommend trying out the new nav right away. This change is inevitable and should help you find Jira information very quickly.
Like Atlassian history? Also read: Evolution of Jira Design
Rachel Wright
Author, Jira Strategy Admin Workbook
Industry Templates, LLC
Traveling the USA in an RV
46 accepted answers
8 comments
