Concept Relates To
Application Type |
Jira Software, Jira Service Management, Jira Core |
Deployment Type |
Jira Server, Jira Data Center |
What is shown?
A permission scheme in Jira Server and Data Center
Visit: Admin > Issues > Permission schemes
What can we learn?
In Server and Data Center, it’s possible to delegate limited workflow and screen editing abilities to project admins. Application admins can turn on these functions with the checkbox labeled “Extended project administration” in a project’s permission scheme.
The conditions for limited workflow editing are:
The workflow must not be shared with other projects or be a default system workflow. In other words, project admins with the extended project administration permission can modify custom, dedicated workflows.
Project admins can add a status to the workflow, but the status must already exist in Jira. Only application administrators can create or edit statuses.
Project admins can remove a status, but only if it isn’t used by any project issues.
Finally, the project admin can create, edit, and delete transitions, but they cannot select or change transition screens, edit transition properties, or edit behaviors like conditions, validators, or post functions.
The conditions for limited screen editing are:
The screen must be custom and not a default system screen.
The screen can’t be shared with other projects or used in workflow transitions.
If both are true, the project admin can add, remove, and reorder system and custom fields. Only application administrators can create or edit custom fields, however.
Note: The "Extended project administration" permission is enabled (checked) by default when new permission schemes are created.
Rachel Wright
Author, Jira Strategy Admin Workbook
Industry Templates, LLC
Traveling the USA in an RV
46 accepted answers
5 comments
