Join Atlassian’s Early Access Program for Priorities per Project in Jira Cloud
[UPDATE: We've now closed this EAP as we're starting our general availability release]
Hi everyone,
We’re enabling Jira admins to set up priority schemes in Jira Cloud. This means you can use different priorities for different projects. We’re looking for Jira admins to join our Early Access Program (EAP) and give us feedback on this feature.
See the below table for details:
What will be available?  By default, all the priorities you have today will be in a default priority scheme for all existing projects. You can:
  • Add or remove priorities in the default priority scheme.
  • Create your own custom priority schemes for specific projects.
  • Edit or delete priority schemes.
  • Manage priority schemes in Jira settings.
Note: We’re not enabling interactions via APIs.
What do you need to do to sign up? Fill in the EAP survey.
Note: If you’re not a Jira admin and you think this will benefit your team, speak with your admin to get involved.
For any questions and clarification
  • Reply to this post for questions about the survey or email me directly on
           nschwartz@atlassian.com.
  • If you qualify, you will be invited to a private community group for this EAP where you can post questions in the group and we’ll get back to you.
What will happen to the feature after the EAP?
  • You can continue to use this feature on your instance.
  • We can enable this feature for production instances if you’re testing on a sandbox as well.
Ready to go? Fill in the EAP survey.
Note: Features in the EAP may have some bugs. We’ll share more details about these bugs, and you can also raise them in the group.
Nicole
50 comments
Yatish Madhav
August 20, 2023
Hi - thanks for this @Nicole Schwartz  - I am signing up! BTW "We’re not enabling interactions via APIs" should end with a "yet" right? Thank you
Like # people like this
Vedant Kulkarni_Trundl
August 20, 2023
Really looking forward to trying out the feature in Jira Cloud.
Rachit Singhal
August 20, 2023
I am happy to see this feature will be implemented in Jira cloud. It is going to solve a big problem for my company. Filled the survey form, excited to be part of this Early access program.
Like Nicole Schwartz likes this
Nicole Schwartz
August 20, 2023
Appreciate the interest! @Yatish Madhav @Vedant Kulkarni_Trundl @Rachit Singhal
@Yatish Madhavfor the EAP, the interactions will not be available via APIs.
Yatish Madhav
August 20, 2023
Super. Thanks @Nicole Schwartz  - yeah, I understand. I hope this will come to APIs once this is generally available - Can I be notifed of that or is there a post or article or issue that I can comment on, upvote and watch or not yet? Thank you
Stacy Clarke
August 21, 2023
Excellent news, @Nicole Schwartz!  Thanks for the update.
Hoffmann, K
August 21, 2023
@Nicole Schwartzwhat happens if we sign up for this eap and decide later to deactivate it?
Will all projects return to the global priority settings without any problems?
And what will happen to the issues within a project that might had a different priority which than would be no longer available?
kind regards
Kai
Rodrigo Angulo
@Nicole Schwartz if we sign up with our sandbox and want to push it to production would that be a hassle? Thanks,
Rodrigo
David Meredith
Will this work like custom field contexts allowing us to set different / default values per Issue Type also?
For example a Change may have very different priorities to an Incident or a Request that exist within the same project.
Nancy Ketchum
August 23, 2023
We are quite relieved to see that we will be able to have different Priorities apply for different Projects. Without this, users often choose Priorities that are invalid.
Nancy
Nicole Schwartz
August 23, 2023
Thanks for all the interest and questions!
@Yatish Madhav you can watch the ticket here
@Hoffmann, K yes we can disable the feature for you which will mean that all your existing priorities will be available for all your projects again.
@Rodrigo Angulo you wont be able to push your sandbox to production.
@David Meredith for team-managed projects, you can set the default value for Priority per issue type but not for company-managed projects.
Rodrigo Angulo
@Nicole Schwartz based on your latest response, could we make an edit on my interest form then? I'd like to apply the EAP to my production env instead.
Nicole Schwartz
August 30, 2023
@Rodrigo Angulo please complete the survey with the url you'd like us to enable the feature on.
Patryk Steczek
August 30, 2023
Hi! Just filled up the survey and I am exited to test this new feature!
Michael Künzler
You'll be getting an email soon...
Like Patryk Steczek likes this
Alp Erguney October 18, 2023
How long does it approximately take between applying to this and getting it enabled? Thanks!
Like Yong likes this
Yong
=> May I know if we have any plan for Company-managed projects to support issue-level permission scheme? @Nicole Schwartz
Nicole Schwartz
October 23, 2023
Hi @Alp Erguneyafter signing up to the EAP, you will be invited to a private community group if you qualify for the EAP. Once you've joined the group, we'll enable the EAP for your instance within a couple business days.
Hi @Yong, priorities per issue type is not something we have planned for as part of this feature at this moment. Here is a feature request for this if you'd like the vote and watch for updates there.
Ben van den Berg
@Nicole Schwartz
Thanks for adding me to the EAP. This will really solve a challenge for many of our customers with the different types of business solutions that we provide.
Nicole Schwartz
November 1, 2023
Awesome, great to have you involved @Ben van den Bergthank you!
Jakub Krauz November 23, 2023
Hi @Nicole Schwartz , is the EAP still open? I have just filled in the survey. We are about to migrate from Jira Server to Cloud soon, and the lack of priority schemes is a pain for us. It would be great if we could get this feature enabled.
Nicole Schwartz
November 23, 2023
Hi @Jakub Krauzyes the EAP is still open! Thanks for signing up and excited to have you involved in the EAP! We have support for migration to Cloud with Jira Cloud Migration Assistant (JCMA). If you're migrating with JCMA and the EAP is enabled for your instance, you can use your priority schemes from Server/Data Center in Cloud.
Great news, thanks @Nicole Schwartz ! That's exactly what I was hoping for.
Swagato Bhatta November 24, 2023
Hi
I just filled up the survey. We are migrating Jira from data center to cloud. I am the Service Manager at Department of Communties and Justice. We will like to have this enabled please for us. Most of our projects have priority scheme. Hence, we need it for successful migration. Migration is runnig from 25th - 30th. Hence, sooner we can have this enabled, better is it for us.
Swagato Bhatta
[personal information removed by community manager]
Nicole Schwartz
November 26, 2023
Hi @Swagato Bhatta, thanks for signing up for the EAP! We're excited to have you involved! I've reached out to you via email.
