June updates are shining bright ☀️ Saved filters, open forms, and more
34 comments
Noushin Kananian
June 23, 2023
Good information. Thanks for sharing your invaluable knowledge and experience.
Like Abby Stiris likes this
Abby Stiris
June 23, 2023
@Jason Basckin what kind of file format would you be looking to export to?
@Muhammad Moazzam Hassan yes, saved filters apply to all Jira Work Management views!
Morgan Watts
Is there an ETA on when the saved filters feature will be rolled out to all users? My company still doesn't have the ability to use the feature.
Like # people like this
Dan Williams
June 29, 2023
@Abby Stiris can you give us a timeline of the roll-out of saved filters?   "Coming soon" doesn't really cut it......daily frustration when they are not there.  I'm sure I'm not alone in this...
Jacob Westergaard Rasmussen
June 29, 2023
Hi @Abby Stiris Still don't see the saved filters. Do you know when it will be fully rolled out?
Like Morgan Watts likes this
Abby Stiris
June 29, 2023
We really appreciate your excitement for saved filters everyone, and we totally understand the need for them. Apologies for the delay — the team is actively working on rolling them out but they're not available yet. I will update here as soon as they are! Thank you
Morgan Watts
@Abby Stiris Thank you for the follow up. Every excited to use the feature when it's rolled out!
Like Monique vdB likes this
Patrick Gregory
July 12, 2023
Is it possible to just open up the forms for anyone to be able to use and submit. It seems like tools like Clickup and Monday.com allow you to share the form with anyone and they don't have to be a registered user of the system. We're using a not great plugin to do this right now but it would help to just be able to share a form link with anyone.
Tere Pile
@Abby Stiris It seems with confluence links avail on board one would 'assume' (bad to assume I know) confluence macros would work - yet, the Jira Timeline Macro sill only works for software projects.  I did find a 'feature' request for this from 2021, but very little movement/comments, any ideas if or when this might happen?
