Guys, I read before that Next-gen project can't log work time. I would like to ask about the list of features that could be developed when I can see them and how I can influence as user for fast developed?
Because my team and I are very appreciate of functionality of boards in next-gen project bit management of tasks is abcent in comparison with classic Jira project.
I can see two useful features here: Roadmap and the long waited function to filter by EPIC on the Agile Board - so useful.
I would like to know WHY these were never implemented on Classic projects: YES to Server: Leave it to a paid add on YES to next Gen: Free with next Gen NO to Cloud Classic but WHY?
@Danielle You don't have the same functionality (add issue directly to board) because you have Sprints feature enabled. This is probably design decision made by Atlassian team because adding issues to running sprint is something agains sprint methodology. Still it is pretty confusing. First I think it is a bug after turning sprints on :(
I think required fields were part of the public roadmap, but now they are gone from roadmap. Is this by mistake or you dont have any plans to make such a functionality in near future?
Also I noticed that Project lead attribute is missing in next-gen project settings. Is this something you want to add later or do we need to figure out some workaround to set project leaders?
Hey @MarekSpalek! Thank you for the quick reply. I tried this option, but it only lets me auto-assign, when switching issues from one column to another. However, when I create the issue it won't auto-assign it.
@Христиана Петкова Oh I see, I actually never tried it 😀 I was thinking that if there is some rule for To-do column it also applies for task creation. Sorry, my mistake.
February 18, 2019 edited
@MarekSpalek for required fields, we had hoped to complete required fields but we ran into some dependency issues that we didn't know about when we had first added it to the public roadmap. We have reverted this piece of work to the backlog until we resolve those issues. Apologies for the inconvenience caused. We are going to be more cautious with adding items to the public roadmap going forward to try avoid this situation.
Are there any plans in Next Gen Projects to support a proper Kanban pull concept which would require grouped columns each with a Done Status for the given columns. Without that proper pull will always fail.
I've had some tickets sitting in "done" for over 25 days now.... I thought "Done" was supposed to auto-archive after 14 days? Any ideas why this might be happening?
February 26, 2019 edited
@Jenny Wanger could you please check if there has been any activity on your issues sitting in done recently? (You can do this by looking at the history tab on an issue you think should have already been archived).
The way board clearing works is that the 14 day counter resets after any change is made to an issue, and this could include things like someone starting to watch the issue or link an issue from a Confluence page.
The Roadmap-View isnt visible in the mobile App, when "Backlog"-Feature is not active. On Desktop i dont have to use the Backlog feature for using the Roadmap. But when i do enable the Backlog feature, i have to drag every new story manually onto the board, because by default it will be placed in the backlog... And nevertheless in the mobile App i dont see the real Portfolio, just a list of the Epics...
@Xer Cha There is no way how to close done task and remove it from board. They will disappear automatically after 14 days.
Alternatively you can turn on sprints feature and than closing sprint removes done tasks from board. But be aware, when you turn on sprints, you will be unable to add task directly to board :(
There are a lot of request for this feature but there is no feedback from Jira team if they are planning implementing this.
Hi, I've also been navigating next-gen today and it seems straight forward at first, but I can't seem to see on where to sort or re-arrange the fields especially the standard ones that aren't visible at the "Issue Type" available field settings such as "Summary", "Description", "Attachment/s" and rest.
402 comments
