The best part about next-gen Jira Software projects is the ability to enable and disable features, allowing you to scale your project as your team grows, and tailor your project to your team’s changing needs. For example, if you’re a small team that only needs a board, you can turn off Sprints and Backlog. Or if you’re a growing team that needs more power, you can turn on Estimations and Reports.
(please note that burnup and velocity reports are available now in next-gen, and more reports will be built soon)
To enable and disable features:
Navigate to your next-gen project.
Select Project settings in the project menu on the left.
Select Features.
We’ll be adding more features in the future, so keep an eye out!
Interested in what's coming next? Please visit the public roadmap
New to next-gen projects in Jira Software Cloud? Check out this guide to getting started with next-gen projects
Would like to know a lot more about next-gen? Watch the new Jira begins now
Hannah McKenzie
402 comments
