Sign up Log in
Next-gen projects "Features" project setting
402 comments
Ajith John
October 21, 2018
Hi All,
Will we have more reports to work with on the Next Gen projects? i have enabled this feature and i see two reports types only?
Dan Stofka
October 21, 2018
When will I be able to use Zephyr and other integrations I rely on?
Martin Koelbaek October 21, 2018
Thanks. Once issue type permissions to make it to the next-gen projects, we'll be able to leverage this for all our teams.
Fredrik Lotto
October 21, 2018
How can I use/enable FixVersion on a next-gen project?
Is it possible to add a kanban-board?
Olga Galanets
October 22, 2018
Thank u, Hannah!
Backoffice
October 22, 2018
Good direction! Is there any way to enable Version//Releases?
MarekSpalek October 22, 2018
I'm also curious about version management, will it make it to the next-gen project? Workaround I'm trying now is to rename Epic to Version and use them for version management. Still, native version management would be really usefull.
Clifford Duke
October 22, 2018
Will this support multiple projects on one board?  I get that in bigger organisations a team might belong to a single project, however in smaller teams, the team handles multiple projects.
Filip Radulović
Just today Jira directed me to learn about this exciting new features but now when I read the article I see that all of this is already 'old news'....
Mark Lehm
October 22, 2018
The new version still feels like a beta and lacks much-needed functionality...
Deleted user October 22, 2018
it's awkward the functionality changes depend on which look ( old or new design) I use. For example, I can change subtasks to tasks but  cannot change stories to epics using old design. In a new design it is the opposite: Can do Epics, Cannot change sub-tasks....
Karen Rivenburg
October 22, 2018
Will this board ever have subtasks?
Carina Verdugo
I use JIRA CLOUD and could not found "Features" in the software project settings menu.
DJ Strader
October 22, 2018
Is it somehow possible to get these features all on one project:
Classic: Releases and Release Notes
Classic-Kanban: Backlog management
Classic-Scrum: Reporting
Next-Gen: Ease of quick set up and card customization
Next-Gen: Roadmap
I can kind of piece all these features together with 3rd-party apps but its messy.
Christina Gheorghe October 22, 2018
I found an answer to my question but can't delete this. Please ignore.
Ryan Holm October 22, 2018
How do you directly convert your classic project into a next-gen project without losing the data (versions, epics, stories/tasks/sub-tasks, development information, etc.)?
Marek Dziedzic
 I too cannot find the "Feature" link under the Project Settings - has this not be enabled for everyone yet?
I found if I created a Next Gen project but checked off "Share settings with an existing project" under "Advanced" then my new project change back to a classic project and "Features" is not visible. If I do not check this off then the NEXT Gen project retains its template and I can see the "Features" option
Max Connolly
October 22, 2018
@Patrick ThompsonIs there a way to have multiple boards under a single project in the new format?
patrickt010
October 22, 2018
@Ajith John Yes, more reports are coming.
@Dan Stofka Yes, we plan on adding support for more apps and integrations in the future. We're currently working with partners to get their apps supported on the new next-gen projects.
@Fredrik Lotto Versions is not available at the moment with next-gen projects. Each next-gen project can only have a single board at the moment, we will ship support for multiple boards in the future.
@MarekSpalek Yes, we plan on adding support for users to manage Versions/Releases in the next-gen project.
@Clifford Duke In the future we will offer a cross-project view.
@Filip Radulović We've been working on next-gen projects for a while but we're starting to promote them more.
@[deleted] @Karen Rivenburg Yes, subtasks are coming!
@Carina Verdugo Features is only available in next-gen projects.
@DJ Strader Nope, but we are adding more features to next-gen so expect the power to grow.
@Ryan Holm You can migrate issues from a classic project to a next-gen project but you'd not be able to use features like versions and subtasks for the time being.
@Max Connolly Not at the moment, but this will be coming in the future.
Shakeel Shaik
Hey guys, Need some help please.
I am trying to figure out how do I navigate to Next-Gen project?
Do I need to upgrade Jira to get into Next-Gen?
*** Got the answer for this. Please ignore!
David Beliveau-Viel
October 22, 2018
@Christina Gheorghe Exactly the info I was looking for. Thanks a ton!
Shakeel Shaik
@Patrick Thompson Can you please let me know if it's possible to migrate classic projects to next-gen project?
Darío Muñoz
October 22, 2018
Is any plan to support Versions? versions are great for Release planning
daniel.alvarez
October 23, 2018
Looks nice! Will releases be also included at some point?
