Sign up Log in
Running Atlassian server product on Docker
Atlassian server products can be installed using a Docker image as well as an installer running directly on your OS.
Official docker image for Jira is published in Atlassian repository in Docker hub, so I will introduce some tips to use Atlassian server products using Docker.
Objectives
The objectives of this article are
  • Starting up Jira, Confluence and Bitbucket on your client machine using Docker
  • Installing each single product
  • Setting up integrations between products
Note, I keep configuration as simple as possible, therefore it's not suitable for production environment. For example, some requirements like data persistence or SSL is not supported on the configuration in this article.
Also, I won't consider connecting via SSH to Bitbucket because it's not necessary for the objective of this article.
Prerequisite
Install Docker on your machine. It may be better allocating enough memory for Docker when you boot multiple containers. I confirmed steps in this article with the following environment.
  • Docker Desktop 2.1.0.3 on macOS Mojave (7 GB memory allocated for Docker)
  • Jira 8.4.0
  • Confluence 7.0.1
  • Bitbucket 6.6.1
Installing and setting up each product
Jira Software
1. Open terminal and hit following command
docker run -d -p 8080:8080 atlassian/jira-software:latest
2. Open following URL with your browser
http://localhost:8080
Confluence
docker run -d -p 8090:8090 atlassian/confluence-server:latest
http://localhost:8090
Bitbucket
docker run -d -p 7990:7990 atlassian/bitbucket-server:latest
http://localhost:7990
You've done! Services run inside container by docker run command, and start listening on each port, so you can go to setup page.
In this step, proceed to evaluation setup choosing embedded database.
Setting up integration of products
Above step is quite simple if you want to try using single product, but it's not sufficient if you wanted to try integrations of each products.
Because each container that is running services doesn't belong to same network and can't communicate each other.
There would be several ways to let each container communicate. Here, I'll introduce a way to boot multiple containers in a same network utilizing docker-compose.
Requirement
You can try using integration functionalities by fulfilling following requirements at least.
  • Each service in containers can communicate each other
  • Name of each service is resolved by a unique URL
Note about second one. Most of Atlassian product have a configuration named "Base URL" as a unique service URL. Although you can configure multiple URLs for your instances as described in How to create an unproxied application link , it would be more straightforward if you configured as your browser and each product access using unique URLs for each services.
I will show you an example that each service is accessed via following URLs
See following diagram to figure out a network configuration.
Steps
1. First, your client computer has to allow you to access to itself looping back your requests via the above URL.
Easiest way to achieve this is just to add records in your hosts file.
127.0.0.1 jira.internal
127.0.0.1 confluence.internal
127.0.0.1 bitbucket.internal
Otherwise, you can configure local DNS using dnsmasq and letting your client computer to resolve above name as 127.0.0.1.
2. Create following two files and put them on any new directory.
docker-compose.yaml
version: '3'
services:
jira:
container_name: jira
image: atlassian/jira-software:latest
environment:
- ATL_PROXY_NAME=jira.internal
- ATL_PROXY_PORT=80
- ATL_TOMCAT_SCHEME=http
confluence:
container_name: confluence
image: atlassian/confluence-server:latest
environment:
- ATL_PROXY_NAME=confluence.internal
- ATL_PROXY_PORT=80
bitbucket:
container_name: bitbucket
image: atlassian/bitbucket-server:latest
environment:
- SERVER_PROXY_NAME=bitbucket.internal
- SERVER_PROXY_PORT=80
- SERVER_SCHEME=http
nginx:
container_name: nginx
image: nginx:latest
volumes:
- ./nginx.conf:/etc/nginx/nginx.conf
depends_on:
- jira
- confluence
- bitbucket
ports:
- "80:80"
networks:
default:
aliases:
- jira.internal
- confluence.internal
- bitbucket.internal
nginx.conf
events {}
http {
server {
server_name jira.internal;
proxy_read_timeout 600s;
location / {
proxy_set_header X-Forwarded-Host $host;
proxy_set_header X-Forwarded-Server $host;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_pass http://jira:8080;
client_max_body_size 10M;
server {
server_name confluence.internal;
location / {
proxy_pass http://confluence:8090;
server {
server_name bitbucket.internal;
location / {
proxy_pass http://bitbucket:7990;
3. Now you are ready! Run following command and boot containers.
docker-compose up -d
4. Open "Application Link" page in Jira
https://confluence.atlassian.com/adminjiraserver/using-applinks-to-link-to-other-applications-938846918.html
Create application link for Confluence and Bitbucket.
Now you can use functionalities like Jira Issue Macro or Smart Commit
Troubleshooting
Each Docker container consumes about 2GB so some container may not boot properly if memory is not allocated enough.
You can configure memory allocation setting as https://docs.docker.com/config/containers/resource_constraints/
Note
In this article I introduced steps to install Atlassian product with simple configuration and this won't be suitable for production environment. But you will be able to configure to work on your production environment. Please refer to the following documentations for detailed specification.
34 comments
rene_robinson
March 17, 2020
This article needs a bit more on how to access these in my network.
I'm not running on localhost but in a private network like most users. What URL would I use? what about finishing the setup? Connecting to the database?
This article is not finished...
rene_robinson
March 17, 2020
Follow up...
OK, I got thrown by the 127.0.0.1 settings in Hosts.
What this should say is to define the entries in the hosts file as
<serverIP> jira.internal
THEN it's fully correct. My server within my home network is at 192.168.1.2, so all the Docker apps would be accessible from 192.168.1.2. Only use 127.0.0.1 if you are installing this on a machine with a graphical system and you are actually logged in on, such as your laptop.
As far as finishing up, all the apps operate as normal, requesting setup if required. What I don't know is what happens if I re-run the docker-compose with my existing database, i.e. an upgrade...
Have to take a look at how that all unfolds. If I'm lucky, if will see the file that shows the settings and recognize the DB...
Nobuyuki Mukai
March 22, 2020
Hi @rene_robinson, great to hear that you utilize my article to run on your environment.
You are right, use 127.0.0.1 only when you want to run on your client machine for the evaluation. And tweaking hosts file would be the most handy way to resolve the name jira.internal  to point 192.168.1.2. Otherwise setting up a DNS server would be suitable option for larger network.
As for
You can use Docker volume for data persistence. It will keep your database even when you recreated containers.
Hope this helps :)
ReneRobinson
March 23, 2020
Nobuyuki, Thanks for the follow up. I did set up a volume and will have to test the persistence.
One more thing, you may need to increase the 10M on Nginx to 100M if you want to post anything larger than 10M, like photos, etc. Found out when trying to add pictures to confluence.
Thanks for the help.
Jorge Jerez
Hi
First of all thanks for this post, It's being really useful to me.
I'm getting an error with the gadgets URL.
I've added to my host:
127.0.0.1 jiralocal.com
 Then, in docker compose file jira container:
jira:
networks:
- jiranet
ports:
- "8080:8080"
environment:
- "ATL_PROXY_NAME=jiralocal.com"
       - "ATL_PROXY_PORT=80"
       - "ATL_TOMCAT_SCHEME=http"
       - "ATL_TOMCAT_CONTEXTPATH=/jira"
 And Nginx container on Docker compose:
nginx:
image: nginx:latest
volumes:
depends_on:
- jira
ports:
80:80
networks:
- jiranet
And then I have the nginx.conf file like this:
events {}
http {
server {
server_name jiralocal.com;
location /jira {
proxy_pass http://jira:8080/jira;
I can access jira on http://jiralocal.com/jira without any extrange problem, but gadgets return
gadget.common.error.500 and URL base is set to the URL I use to access.
In the logs the error is:
2020-03-24 13:53:17,080+0000 HealthCheck:thread-4 ERROR [c.a.t.j.healthcheck.support.GadgetFeedUrlHealthCheck] An error occurred when performing the Gadget feed URL healthcheck
org.apache.http.conn.HttpHostConnectException: Connect to jiralocal.com:80 [jiralocal.com/127.0.0.1] failed: Connection refused (Connection refused)
I'm running this on W10
Can anyone help me with this?
Nobuyuki Mukai
March 26, 2020
Hi @Jorge Jerez , thank you for your comment!
It seems you encountered Jira activity stream gadget throws gadget.common.error.500 . Jira has to be able to access to itself by base url.
In your case, apparently the request to jiralocal.com is looping back to Jira container itself as it is resolved as 127.0.0.1. You will have to configure your network to let  jiralocal.com be resolved as the nginx container because 80 port is exposed only on the nginx.
I think adding an alias to jiralocal.com in the nginx container will do the trick.
  nginx:
networks:
default:
aliases:
- jiralocal.com
 Hope this helps.
Jorge Jerez
Hi @Nobuyuki Mukai
Thanks for your comment, yesterday I tested that way and worked for me, I'm new on Docker so I have a lot of thing to learn.
Anyway, some people with experience in Docker ask me to use Traefic instead of Nginx or Apache, because work better on Docker, do you know something about this?
Nobuyuki Mukai
March 26, 2020
Hi, @Jorge Jerez , Great to hear that worked in your environment :)
And as for traefik, yes, I believe it can be an alternative to Nginx. I've used traefik before for testing purpose, and it was working fine as far as I tested. Also I found someone who configures traefik with Atlassian products --
Tobi_P
April 7, 2020
@Nobuyuki Mukai As I understood application links are using O-Auth authentification to establish the link. Even though: is there a possibility to preconfigure application links in the docker-compose file (maybe by providing credentials for a admin user account, which should be created on startup)?
Nobuyuki Mukai
April 7, 2020
hi @Tobi_P , unfortunately, the Atlassian's docker images don't support the configuration to the application link.
Though this is unofficial and I cannot guarantee that it will work, the workaround in https://jira.atlassian.com/browse/JRASERVER-61753 may help the automation of the application link creation process. Please vote if this feature request interests you.
andybandy89 June 26, 2020
Hi @Nobuyuki Mukai
Thanks for this great article. I had this idea for a long time and then with the help of your article finally implemented it. Our DEV and TEST environments for Jira and Confluence are running on Docker now since almost a half year. We have done some further configuration and described it here:
http://coffeetime.solutions/run-atlassian-jira-and-confluence-with-postgresql-on-docker/
Thank you very much!
Nobuyuki Mukai
June 28, 2020
Hi @andybandy89
Thanks for your comment! I'm happy to hear that my article helped you :)
aarti rajput June 30, 2020
Thanks @Nobuyuki Mukai
This is really helpful while setting up jira ,confluence on a same platform.
However i was facing issue while running docker-compose up -d
Error:
Status: Downloaded newer image for nginx:latest
Creating jira ... done
Creating confluence ... done
Creating bitbucket ... done
Creating nginx ... error
ERROR: for nginx Cannot create container for service nginx: status code not OK but 500: {"Message":"Unhandled exception: Filesharing has been cancelled","StackTrace":" at Docker.ApiServices.Mounting.FileSharing.<DoShareAsync>d__6.MoveNext() in C:\\workspaces\\stable-2.3.x\\src\\github.com\\docker\\pinata\\win\\src\\Docker.ApiServices\\Mounting\\FileSharing.cs:line 0\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n
P.S. I have updated the c and d drive as well in file sharing. please suggest.
Nobuyuki Mukai
July 8, 2020
Hi @aarti rajput
It sounds like you are facing https://stackoverflow.com/questions/60754297/docker-compose-failed-to-build-filesharing-has-been-cancelled . Did you restart Docker for Windows after updating the file sharing section?
aarti rajput July 9, 2020
Thanks for Reply @Nobuyuki Mukai .
But File sharing is already enabled and docker is restarted also. its working if i commented volumed section in docker-compose.yml.
with mounted volume its not working
nginx: container_name:
nginx image: nginx:latest
volumes:
depends_on: - jira
Nobuyuki Mukai
July 9, 2020
@aarti rajput
It sounds like a problem of Docker for Windows or Windows OS itself. Do you use the latest version of the Docker?
Otherwise you may be able to avoid the usage of mounted volume for nginx by tweaking the compose file a bit.
For example, change the nginx section of docker-compose.yaml to build from docker file
nginx:
build:
context: .
dockerfile: nginxdockerfile
ports:
- "80:80"
and locate a file nginxdockerfile in a same directory.
FROM nginx:latest
COPY ./nginx.conf /etc/nginx/nginx.conf
That will create a nginx container which already includes nginx.conf without using mounted volume.
Alexander Meier
August 6, 2020
Hi @Nobuyuki Mukai and thanks for this article!
It worked great on my notebook for a local first test. But now I wanted to run the same on a different little server and I'm having problems to get it configured properly.
The problem is that on that small server we already have a native webserver running that handles requests for ports 80, 8080 as well as 443 and some more (and in addition we also have a few docker / docker-compose apps running which use local port forwarding but on unrelated ports)
The problem I'm having now is that whilst the containers themselves seem to come up, I can't really access them through the browser with nginx as reverse-proxy. The only one that seems to be working correctly is Jira, which I can access through the browser.
Since the small server is reachable on our internal network at 'ourlittleserver.ournetwork.private' I changed the Env vars as follows for the 3 containers
[ATL|SERVER]_PROXY_NAME=ourlittleserver.ournetwork.private
[ATL|SERVER]_PROXY_PORT=8095
# and in the nginx service spec:
ports:
- "8095:80"
I assume that I have to set some more Env-Vars for my specific setup and maybe also change some more port settings.
But it feels a bit like searching for the needle in the hay stack.. any help to speed up my process is greatly appreciated ;-)
Nobuyuki Mukai
August 25, 2020
Hi @Alexander Meier thanks for commenting on the article!
If your nginx server listens only for "ourlittleserver.ournetwork.private", all the browser request will be passed to single destination in the backend.
In my sample, nginx is sorting out the request using name based virtual hosting.
nginx.conf has multiple servers
http {
server {
server {
 and docker containers are waiting for these request with the environment variable
    environment:
environment:
I hope this helps.
Tom Stieger
September 22, 2020
FYI- your link the the docker resource constraints looks to have a couple extra characters at the end (%C2%A0).
This link works though: https://docs.docker.com/config/containers/resource_constraints/
Nobuyuki Mukai
September 22, 2020
Hi @Tom Stieger
Thanks for pointing out my mistake. I fixed the link :)
marc September 8, 2021
what about https://hub.docker.com/u/atlassian ? It seems empty.
How can we fix the security issues with confluence running in docker?
Thanks and kind regards!
Jonny Carter
September 22, 2021
This article is still relevant & helpful, particularly the docker-compose configuration. Thanks, Atlassian!
One small note, if you're like me and want to install plugins larger than 10 MB into the resulting container, you may need to tweak the nginx.conf file a bit.
 client_max_body_size 100M;
If you're getting cryptic errors in UPM when installing the add-on and seeing HTTP 413 errors under the hood, this tip is for you!
I imagine this is relevant to other upload needs, like uploading large attachments to Jira, Confluence, and Bitbucket.
Like Nobuyuki Mukai likes this
Greengoatsoftware April 26, 2022
First of all nice guide, but have noticed a little typo you may want to correct on the next page update.
Near the top where you describe how to quickly get containers up and running for each Jira, Confluence and Bitbucket instances, in the Bitbucket section you have the commands correct for the docker container but below it where you list the URL to go to you have listed Confluence's port number (8090) instead of Bitbucket's (7990).
Like I say its only a very tiny typo but it could trip up new users or those not used to having different containers on the same machine and accessing each one just with a change to the port number. :-)
Nobuyuki Mukai
April 27, 2022
Hi @Greengoatsoftware thanks for pointing out the error. I fixed the typo to point to the right URL :)
Like Greengoatsoftware likes this
Jean-Philippe M January 31, 2023
@Nobuyuki Mukai Thank you for the article.
Can you clarify a comment you made "unfortunately, Atlassian's docker images don't support the configuration to the application link".
Is it still the case with the current version?
Does it mean that I cannot link JIRA with Bitbucket and Bamboo? I am preparing a training environment for doing CI with Atlassian products.
Thank you
Have a nice day
