Running Atlassian server product on Docker
34 comments
Jean-Philippe M January 31, 2023
I tried to add the application link but
We couldn't connect to Bitbucket, possibly because that instance is behind a misconfigured proxy.
We couldn't connect to Jira, possibly because that instance is behind a misconfigured proxy.
FYI, I have tried to create the application link with both URLs pattern
Nobuyuki Mukai
January 31, 2023
Hi @Jean-Philippe M
> Does it mean that I cannot link JIRA with Bitbucket and Bamboo?
You can connect Jira, Bitbucket and Bamboo with Application Link manually. What I meant was that you cannot configure Application link automatically using docker-compose.yml.
To make "bitbucket.internal" or "jira.internal" url pattern works like the example in this article, the following nginx config is essential. You need to set "http://bitbucket.internal" or "http://jira.internal" as base urls too.
  nginx:
networks:
default:
aliases:
- jira.internal
- confluence.internal
- bitbucket.internal
Like • Jean-Philippe M likes this
I have it
maybe it is due to the docker network I have added?
@Nobuyuki Mukai I found out I made a mistake in the network definition of the docker-compose.yml.
The application links are marked as connected now.
Like • Nobuyuki Mukai likes this
Jean-Philippe M January 31, 2023 edited
@Nobuyuki Mukai I have another issue... When I try to add a repository on bamboo, which I have added to complete your article.
I have errors
http://bamboo.internal/project/createProjectRepository.action
  • New access key is required but could not be added to Bitbucket Server.
  • Warning: Permanently added '[127.0.0.1]:37181' (RSA) to the list of known hosts. BAMBOO-SSH-PROXY: [SSH proxy tried to connect to [git@bitbucket.internal/192.168.80.7:7999]: and failed due to the following error: [Remote connection failed]: Failed to get the session.] fatal: Could not read from remote repository. Please make sure you have the correct access rights and the repository exists.
I have exposed port 7999 on the docker-compose for bitbucket
I can connect to the bitbucket ssh using Putty
If I look, http://bitbucket.internal/plugins/servlet/ssh/projects/DEMO/repos/demo/keys, I see the key has been added
Any idea what I have to do to make it work?
Nobuyuki Mukai
January 31, 2023
@Jean-Philippe M
Grad to hear that the applink worked :)
As for the Bamboo setup, I think your bitbucket.internal/192.168.80.7 points to your nginx container. Try adding ssh upstream configurations to your nginx.conf.
e.g.
stream {
upstream ssh {
server bitbucket:7999;
server {
listen 22;
proxy_pass ssh;
Jean-Philippe M February 1, 2023 edited
@Nobuyuki Mukai
I have added the suggested stream configuration but without success...
Still has the same kind of message
  • Warning: Permanently added '[127.0.0.1]:33591' (RSA) to the list of known hosts. BAMBOO-SSH-PROXY: [SSH proxy tried to connect to [git@bitbucket.internal/172.19.0.7:7999]: and failed due to the following error: [Remote connection failed]: Failed to get the session.] fatal: Could not read from remote repository. Please make sure you have the correct access rights and the repository exists.
It is strange that it says that it cannot add a key but the key is added.
And I can clone the repo I have created through ssh with a key I have added manually.
Well, it is better with a matching port
At least now it appears in the repo list of my project into bamboo...
stream {
upstream ssh {
server {
listen 7999;
proxy_pass ssh;
 Thanks for the help.
Now I can learn how to works with everything linked
@Nobuyuki Mukai Maybe you can update the article to add Bamboo ;)
