Search Jira from your Browser
Are you still opening Jira to search Jira? That’s so 2020! There’s a much faster way. Instead, use your browser’s “search engines” feature to quickly jump to Jira projects, issues, and pages.  No navigation or clicks required!
This is my absolute favorite Jira tip because it saves time. Once it’s set up simply type a specific set of characters to jump straight to your favorite Jira locations!
Example
In the video (link below), I’ve set my browser to take me to the “DEMO” Jira project when I type:  “p tab DEMO” in the address bar.
After I type “p” and a space, my address bar changes to a search bar that looks like the screenshot below.
Notice how the address bar changes
After I type “DEMO” and press the “Enter” key, I’ll be directed to the DEMO project in Jira.
Similarly, I’ve designated the “i” character to go to a specific issue ID and other characters for other frequently accessed Jira admin pages. Here’s how to set it up:
Chrome Browser Instructions
Let’s set up the “i” character to visit a Jira issue like in the example above.
  1. Launch the Chrome browser
  2. Right click in the address bar and select “Manage search engines”
  3. Click the “Add” button next to the “Other search engines” header
  4. In the “Add search engine” overlay, enter:
    • “Jira Issue” in the “Search engine” field
    • “i” in the “Keyword field
    • https://your-jira-url.com/browse/%s” in the “URL with %s in place of query” field
  5. Click the form submission button
Chrome “Add search engine” overlay
The “%s” in the URL is a variable and represents a word or phrase you’re searching Jira for.
That’s it! To try it out, type the “i” key, then the “tab” key, then any Jira issue ID in the browser’s address bar.
Example: “i tab DEMO-1
The browser will take you directly to the URL for issue DEMO-1. It’s easy and the possibilities are endless!
Sample Jira URLs
To craft other Jira search URLs, simply find a location in Jira, copy the URL in the address bar, and substitute “%s” for the variable search term. Here are some examples:
Other Applications and Websites
Use this search trick with other websites too
You can this same trick with other applications and websites that have predictable search URL patterns like, Confluence, Dictionary.com, Twitter, and even your own website. I frequently use “d tab word” to look up a word at dictionary.com.
You can also do this in other browsers. Here are the Firefox instructions, for example.
17 comments
Kat Warner
Image result for wow gif
Rodney Nissen - ReleaseTEAM
February 11, 2021
Now to figure out how to do this in Firefox....
Still, a great quick how-to @Rachel Wright!
Christian Macy September 3, 2021
The only issue I can see is that there doesn't appear to be a way to support multiple Jira URLs. The search engine name is "Jira" regardless, so you can only add it once—i.e. for one Jira URL.
Otherwise it's certainly handy!
Like MohammedAthiq.Shaik likes this
Rachel Wright
September 14, 2021
Hey @Christian Macy, just create one search engine record for each "type" of Jira URL you want to use.
For example, I have three records: "p" for Jira projects, "i" for Jira issues, and "b" for Jira boards.
Ex: Typing "p [tab key] DEMO" takes me to https://your-jira-url/projects/DEMO
Hope that makes sense!
Christian Macy September 14, 2021
Thanks @Rachel Wright ! Unfortunately I can't find a way to make that work with Firefox. You can change the shortcut for an engine, but not the name, so AFAICT in Firefox you can only add one record. :-(
You're right WRT Chrome, though—Chrome allows you to specify a name for an engine when adding it.
I commented on a relevant FF bug report providing some more info, but I'm not sure it'll go anywhere in the near future. If the search engine name included something relevant to the context (e.g. the account name and search type) then this wouldn't be an issue, but I'm not sure where to request this change on the Atlassian side.
Corey Puffalt
February 28, 2022
@Christian MacyThere's another way to achieve something very similar in FireFox.  This is done by adding bookmarks with the Keyword field filled in.  For example you define a bookmark similar to what is mentioned above.  Use %s for the placeholder value (similar to Chrome above).  The keyword field defines the "shortcut" that directs the search to your bookmark.  For example define a new bookmark where Name = "JIRA Account 1", URL = "https://<sub-domain>.atlassian.net/browse/%s", Keyword = "i1".  You can then define other bookmarks for other accounts simply by modifying the subdomain and keyword values.  To perform a search simply type "<keyword><space><search-text>" into the URL bar.
Like Christian Macy likes this
Christian Macy March 1, 2022
@Corey Puffalt: That is EXTREMELY handy. Thank you! I had no idea we could use string interpolation in bookmark URLs. I'm usually looking for a specific story number, so this works out really well for my use-case.
Matt Ball
July 8, 2022
Here's another option to try, which seems to provide the same search intelligence as when typing terms into the search window of Jira itself:
https://<your-subdomain>.atlassian.net/secure/QuickSearch.jspa?searchString=%s
This has the advantage that if you type a ticket number, it directly opens the ticket, but if you type another search term, it opens a search results window.
Like # people like this
Christian Macy July 8, 2022
Thank you, @Matt Ball ! That was a really great tip. I've added a new bookmark with this trick and so far it's fantastic. I love that a story number (without prefix) will be found right off, but arbitrary text will result in a search. Excellent!
Like Matt Ball likes this
Danny Derks
This is a nice one! @Matt Ball , that searchstring update is great. Really usefull!
Chris Hadley
January 17, 2023
I recently switched to Firefox for work and have been looking for a way to quickly jump to a ticket. Thanks @Corey Puffalt and @Matt Ball for the helpful tips.
Iris Gu
February 2, 2023
This article is exactly what I need. Thank for your sharing ... Very Useful!
Shahrukh Vhora
December 12, 2023
@Matt Ball The best search URL, better than any other JIRA URLs in this post. Thank you!
Robert Laviolette February 14, 2024
Do anyone know the url tu use for Jira cloud search engine?
Travis Vetter May 28, 2024
The new AI search would be ideal for this.  However it looks like the "AI" option processes it's input prior to the URL being generated...   So %s doesn't have the AI feature available.
FEATURE REQUEST: Update the search to include the ability to use the AI interpreter from the URL.
Is this being tracked?
Edwin
June 2, 2024
@Travis Vetter Google had auto-generated the shortcut for me: https://[insert-jira-url]/secure/QuickSearch.jspa?searchString=%s
replace the url and you should be good to go!
Travis Vetter June 4, 2024
@Edwin  Thank you, but that doesn't work.  the "QuickSearch" jsp converts to the JQL "text~="<your search>".
What i'm looking for might look like "AISearch.jspa" and then be the input to the AI system.
Example "My Open actions" using your link above produces (approx)
JQL: text ~= "My Open Actions"  <- Useless
The AI feature produces:
JQL: assignee = currentuser() AND statusCategory != "Done"   <- Useful
I think this is a new feature, but it should be extremely quick and easy and then we can do AI-JQL from the site-search URL and that would be very helpful.
