Hi everyone,
I’m a Product Manager for Jira Software Premium edition. I’m here to announce that we shipped a new template to help customers start planning at scale. The feature is rolling out the week of July 24th.
The Top-level planning template is designed to help customers with existing Jira Software data create a high-level overview of their organization’s work by:
creating a pre-configured plan with the above project as the issue source. The plan is the best place to create, plan, and track the initiatives you'd create.
demonstrating how to connect existing epics to your newly-created initiatives
On this page, we’ll go into detail about how this template helps customers get started with planning and tracking work above the epic level faster, and where you can find this new feature.
If you’d rather just explore it yourself, here’s how to find this new feature in Jira Software Premium:
From anywhere in Jira Software, select Projects > Create project from the top menu.
In the Software development tab on the left (which is the default tab), select the Top-level planning template.
Don’t have Jira Software Premium? No problem – you can try it for free right now!
One of the most powerful features of Jira Software Premium that helps organizations plan at scale is the ability to create and manage issues at hierarchy levels above Epic in Advanced Roadmaps. By default, this level is called Initiative, though you can change this later to match your organization’s structure. Learn more about configuring hierarchy levels in Advanced Roadmaps.
Initiatives compile Epics from multiple teams to achieve a much broader, bigger goal than any of the Epics themselves. While an Epic is something you might complete in a month or a quarter, Initiatives are often completed in multiple quarters to a year. Learn how to plan with hierarchy levels above Epic.
The Top-level planning template automatically creates this new hierarchy level, and shows you how to use it in an Advanced Roadmaps plan with existing Jira Software data.
This template:
creates the Initiative hierarchy level
creates a project and an Advanced Roadmaps plan
The project is where the Initiatives you’ll create live, but it’s not used in the top-level planning process. After you use the template, you’ll land in your Advanced Roadmaps plan since managing hierarchy levels above Epic (like Initiatives) is easier in a more-visually appealing, hierarchy-based view. This’ll make more sense when you see it.
As you go through the tutorial, here’s what you’ll accomplish:
To start, create your first Initiative.
Next, add an existing project, board, and/or filter to this plan.
In Advanced Roadmaps, we call these Issue sources. For this tutorial, we recommend that you use issues from company-managed projects, and that they contain at least one Epic. Learn more about issue sources in Advanced Roadmaps.
Finally, reparent your existing Epics to the new Initiatives.
This creates an association using the Parent field, linking the two issues. You’ll see that the Initiative now shows the data from the Epics contained within. This is called a roll-up; Advanced Roadmaps infers values of parents from child issues, and they’re super useful for keeping your plan up to date. As you add more Epics to the Initiative, the estimates and dates will update along with it. Learn more about roll-ups in Advanced Roadmaps.
Before you’re done, you’ll see a prompt about how Advanced Roadmaps is a sandbox environment, meaning you need to save your changes before you’ll see them on any boards or projects outside your plan. Learn more about saving changes made in Advanced Roadmaps.
This is the first new template we’ve created to make getting started with Advanced Roadmaps easier, and we want to hear what you think. Was this template easy to use? Did it help you create your first plan? What can we do to improve it? What other templates can we make?
Let me know in the comments section of this post!
Roi Fine
Senior Product Manager
Atlassian
30 accepted answers
23 comments
