2-legged OAuth is not properly configured on the remote stash end
josh gold
This is the error I get when I try to create a trigger.  However, testing OAuth config on Ingoing/Outgoing on Stash and JIRA says it is configured correctly.
Sarika Dalal
I am Also Having the same problem here
Ansar Rezaei
April 4, 2016
Same problem Here!
ryanhaman July 30, 2015
I had to remove the existing applications links and re-create them to get this to work. Our problem started after upgrades to both JIRA and Stash. Apparently the newer versions have new features on the application links.
Perry Moutzouros
October 21, 2014
having the same issue today. Anyone have any ideas? I have the IP addresses wildcarded on both ends...
Register now
