ACP 100 Certification - Product Version Help
Ajit Rajput
The current Exam Topic guide on Certification states Product Version 7. Does this mean the exam questions will be specific to exact Jira 7.0 or higher ( i.e. 7.1 to recent 7.11)
Pls help me understand so that I can focus on exact Atlassian documentation.
Anton Chemlev - Toolstrek -
February 11, 2019
Hi Ajit,
All questions will be specific for Jira 7 in hole. You'll be asked about features common for versions since 7.x.x up to current. I don't remember questions specific to exact version.
Take last Jira 7 version documentation.
Ajit Rajput
This may be like being over-cautious - but I should not assume and end up answering the question wrong, just because certain feature/s which were not part of older 7.0 but were introduced in later versions.
Hence seeking advice from certified jira administrators.
February 11, 2019
So, I'm certified - ACP-100 )))
All the questions are aimed to check your overall knowledge of system and ability to give advice to customers for better implementing Jira. No catchy questions on tiny features at all.
Ajit Rajput
Thanks @Anton Chemlev - Toolstrek - No doubt ! 😊
Your response surely did answer my query and cleared the confusion.
Thanks Again !
