ACP-600 Exam Preparation
Deleted user October 10, 2018
In the ACP-600 Exam Details document, one of the important concepts to master is:
Which configurations (schemes, versions, components, etc.) are shared versus unique when new projects are (1) created from template or (2) with a shared configuration?
Some clarification on this subject would be highly appreciated.
Martin.
8 votes
Manon Soubies-Camy
Hello @[deleted],
I haven't taken the ACP-600 exam but the ACP-100 and ACP-400 ones, you'll find details on this in the documentation:
About shared configurations:
- When you create a new project from a template, that project is created with its own set of schemes. These schemes are:
  • a permission scheme (default)
  • a notification scheme (default)
  • an issue security scheme
  • a workflow scheme
  • an issue type scheme
  • an issue type screen scheme
  • a field configuration scheme (default)
- Sometimes you may wish to share schemes among your projects, so that editing one scheme changes that scheme in several projects at once.
- You can select Create with shared configuration to select an existing project and to use that project's schemes. Note that when you're sharing schemes, any change to the scheme will affect all the projects using that scheme.
Hope this helps and good luck with your exam!
- Manon
Alexander Bondarev
May 29, 2019
Hi, @Manon Soubies-Camy !
Have you wrote any articles about your exams experience?
I’m interested in ACP-100 and ACP-400.
Have you started from ACP-400?
Fahad Siddiqui
December 23, 2019
@Manon Soubies-Camy
i am getting this message "Your cart contains voucher only exams. Please enter your voucher code to proceed." can you help in this?
Julia
December 24, 2019
Exam ACP-600 can be paid for only with a voucher.  The exam and the preparation course come as a bundle.  Visit this page for the details: https://www.atlassian.com/university/certification/certifications/exam-acp-600
Like # people like this
Huili Meng September 2, 2020
 shared configurations should also include:priority scheme
Edwin David
May 6, 2021
Please share the document link to prepare or ACP-600
Marynel Soto
Hi @Manon Soubies-Camy I found information that I believe is a bit contradictory?
From page 23/147 in the skillbuilder Issue Security in Jira:
"When projects are created from a template, they inherit 7 of the 8 schemes, including:
• Issue Type Scheme
• Notification Scheme
• Permission Scheme
• Workflow Scheme
• Issue Type Screen Scheme
• Field Configuration Scheme
• and Priority Scheme
By default, projects created from template do not inherit an Issue Security Scheme."
Manon Soubies-Camy
Hi @Marynel Soto,
I've done some tests on both Jira Server and Cloud and can confirm that issue security scheme is copied when creating a project with shared configuration.
It is a bit confusing, you need to distinguish "Create with shared configuration" (i.e., copy a project) from "Create from template" (e.g., based on a general template like Scrum or Kanban). So, to recap:
  • When creating a project from a template (Scrum, Kanban...), the new project does not inherit an issue security scheme.
  • When creating a project with shared configuration (i.e., based on an existing project), the new project does inherit an issue security scheme.
Hope this helps!
- Manon
Marynel Soto
Great! Thanks!!
Like Manon Soubies-Camy likes this
