API Timestamp error
Debraj neogi May 12, 2016
We are seeing a discrepancy in the format in which the time for bug creation is being returned on Stage and PROD environments for JIRA.
When we are making a call to JIRA stage environment to fetch bug details, the timestamp for Created being returned is: 2016-03-14T06:08:27.000-0700. While making the same call on PROD, returns the timestamp as: 2016-04-29T09:18:27.000+0000
Is there some system setting we need to tweak to resolve the differences?
Thanks.
Nic Brough -Adaptavist-
May 12, 2016
What do the created dates on the issues you are pulling say when you view them in the UI?
Hi Nic,
Created: 22/Apr/16 20:21 on UI.
May 12, 2016
On both issues?
Also, when you say "making a call", what is that call?
On prod:
Created:22/Apr/16 20:21
On stage:
Created:14/Mar/16 18:38
API call: /rest/api/2/issue/ISSUE-ID
May 12, 2016
Ok, I think I can explain staging - the date/time you get over REST is the raw date/time stamp on the data.  The UI is shifting the display because of your time-zone settings.
The date in production makes no sense to me though.  It's as though you're looking at a totally different issue in the UI and over REST.
Help us plant more trees
