AUI Dialog in Dialog JIRA 5.1
jan.dolezal September 6, 2012
im trying to show another dialog with AUI in Edit Dialog (Jira 5.1), but when ill click on button, edit dialog will dissapear.
edit.vm
var popup = new AJS.Dialog(860, 530);
    AJS.$("#test-button").click(function() {
        popup.show();
Is there any callback in function for edit dialog ? or..
BenA
September 9, 2012
You can see examples of stacking AUI dialogs at http://docs.atlassian.com/aui/latest/demo-pages/dialog/dialog-demo.html and full documentation at https://developer.atlassian.com/display/AUI/Dialog
...not sure where to find docs about JIRA's callbacks though.
Quentin Genies
Same problem here. Did anyone manage to solve that without having to use an external framework? I would like to keep JIRA AUI's design...
Wayne Westmoreland January 6, 2014
Using JIRA 5.2 I could not get this to work. Calling the show method on an AUI dialog while another dialog was showing would close the 1st dialog.
However, it does work with JIRA 6.0 and later, except for the cosmetic issue of the 1st dialog not being dimmed. JIRA 6.0 uses a much later version of AUI (https://developer.atlassian.com/pages/viewpage.action?pageId=1278074)
Register today
