Sign up Log in
Ability to create a configurable UI elements in JIRA
Gregory Ananev
April 10, 2019
Hello community!
Is there any method (mb 3rd party solution) to create a configurable UI elements in JIRA?
For example: as a project admin I want to create a new button(macro)/tab/panel for particular project's issue type in a few clicks. It should be possible to bind some actions on the button (e.g. comment issue+change the status + add the labels). It should be possible to place these buttons (macros) on the tab/panel created or a view screen.
Important: the solution should not be based on any scripting, because, in our case, project admins are not a technical experts OR have no time to create a custom solutions which are based on Script Runner Fragments or any addons, which have no user-frienldy interface.
Thanks ahead for your comments!
Aleks Yenin (Polontech)
April 10, 2019
Hi Gregory!
If you don't have any chance to make it on your own in your company, our specialists can help you with it and customize and integrate a Jira add-on with all functions you need.
You can learn more details here: https://polontech.com/atlassian-custom-development/jira-custom-addon-development/
