This question is in reference to Atlassian Documentation: Importing data from Bugzilla
When using the bugzilla import option I see that it is automatically trying to map and create all of my custom fields. The problem is that don't want to have all of my custom fields brought over. How can I prevent this?
I am having the same problem, what I will probably do is to import them into the new custom fields. From there if I do not need the data I will simply delete the custom field, for the other I will do a global copy field to the correct field.
I recommend that you create a feature request for this though as I would vote for it!
Register now
