About migration from MySQL to PostgreSQL
Sergey Manokhin July 7, 2015
Hi!
How i can migrate from jira 4.4 with MySql to jira 6.4 with PostgreSql?
I use these instructions:
  1.  Upgrading JIRA (no change of database) - see https://confluence.atlassian.com/display/JIRA/Upgrading+JIRA
  2. Changing the database - see the database parts of https://confluence.atlassian.com/display/JIRA/Migrating+JIRA+to+Another+Server (it's basically down to "export data, point JIRA at new empty database, import data", but you need to check over all the steps in there))
But i constantly have error: (ERROR: invalid byte sequence for encoding "UTF8": 0x00).
My actions:
1) I backup my data (xml file) from JIRA 4.4 with MySQL DB. — OK
2) Install JIRA 6.4 with MySQL. — OK
3) Restore data from xml backup. — OK
4) Backup data (xml file) from new JIRA 6.4 with MySQL DB. — OK
5) Install PostgreSQL 9.3 (supported by jira). — OK
6) Stop JIRA 6.4. Delete dbconfig.xml. Start JIRA 6.4.
7) Configure connection with PostgreSQL DB. — OK
8) On next configuring step i choose "Import data". — OK
9) Type backup file name. Insert license code. Start restore. — OK
10) I see parsing process. After few seconds i getting error message.
Any ideas?
Thank you!
David Di Blasio
July 13, 2015
Hi Sergey,
From the wording in the error it sounds like you might hitting  the behavior described in the following article:
https://confluence.atlassian.com/pages/viewpage.action?pageId=389285646
Try running the xmlcleaner and see if this helps out.
Cheers!,
David Di Blasio
