×Hello everyone,
I got a problem to access a SSL secured Jira with PowerBI via REST API.
My situation:
- I can use REST API via Chrome, where I installed the SSL certificate to chrome using a line like "XYZ/jira/rest/api/2/search?jql=..."
- Within PowerBI I only find a way to include credentials, but non to implement a ssl certificate
Possible solution:
- When including the SSL certificate to PowerBI I should be able to access Jira via REST API.
--> How do I get the SSL Certificate included for permisson at PowerBI?
Thank you in advance :)
You can use our plugin.
For the server - Microsoft Power BI Connector for Jira
For cloud - Microsoft Power BI Connector for Jira Cloud
Our plugin has convenient data filtering. You will be able to filter your data by JQL, Date and Jira Filter.
We also integrated with a large number of plugins.
For all questions, please contact support@doit-bi.com
We respond quickly
