Active Directory Groups won´t be correctly synchronized in JIRA
Andreas Bücking March 18, 2016
Hello Myatlassian,
I faced following Issue while synchronizing our Active Directory Groups with the JIRA User Directories. Is it an JIRA Issue or just my fault on configuration settings?
Thanks in advance!
Best Regards
Chander Inguva
March 18, 2016
HI Andreas,
                   Perform Full Synchronization browsing User Directories and observe logs and send us if you find any Errors which will help us identify the issue.
Meanwhile, based on your JIRA version search for any possible issues under
https://confluence.atlassian.com/jirakb/jira-application-server-user-management-knowledge-base-776825013.html
Regards
Chander Inguva
