We are using JSM 9.12.5 and today our Activity Stream is showing an error:
Requests to https://10.232.232.61/rest/activity-stream/1.0/preferences are not allowed. See your administrator about configuring a whitelist entry for this destination (http://confluence.atlassian.com/x/KQfCDQ).
Requests to https://10.232.232.61/plugins/servlet/streams?maxResults=5&relativeLinks=true are not allowed. See your administrator about configuring a whitelist entry for this destination (http://confluence.atlassian.com/x/KQfCDQ).
I assume it's because the Gadget is referring itself via ip address and not via Base URL (FQDN of instance).
Anyone got suggestions about that ?
@Luca Deboli I have seen this fixed with a simple reboot after the base url has been updated. If you are running a proxy it could also cause the issue and it will require you to fix the server.xml and ensure it is setup for a proxy.
