Activity steam not work
Anton Liskov January 9, 2018
After update Jira Core to 7.6.2, own Activity stream is not work.
SMS
January 9, 2018
Hi Anton,
What version are you coming from?
Another user had an issue after upgrading and it was noticed there was a change in Jira since 7.3.2.
This involves Windows. Could you tell us if you're running Jira on a Windows machine? If so, can you try this fix?
From the above articles, it is possible to modify the Windows Registry and increase the UrlSegmentMaxLength value to handle more characters:
  1. Backup the Registry
  2. With Regedit, browse to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\HTTP\Parameters
  3. Find the value for UrlSegmentMaxLength (or if it doesn't exist add a DWORD value), and change it to 00001000 (this is the hex for 4096)
Powershell alternative:
Set-ItemProperty -Path HKLM:\System\CurrentControlSet\Services\HTTP\Parameters -Name UrlSegmentMaxLength -Value 4096
After using either method to adjust the registry (Regedit or Powershell), you must restart Windows for the changes to take effect. This will necessitate downtime, please plan a maintenance window accordingly.
Thank you!
Shannon
Good news!
It's work!
But I can't configure gadget Activity Stream behing IIS
Via server, it's work
This is my browser cash trouble!!
All right!
Thanks you for your help for as!!!
SMS
January 10, 2018
You're welcome Anton! So everything is working now as expected?
Shannon
Anton Liskov January 11, 2018
Yes, it works! thanks for the support, please close the ticket
