Hello
I've got two, very similar installations of JIRA. One is 5.1.5, second one is 6.4.
I am unable to get the Activity Stream running on the 6.4 instance (they don't share same database, these are JIRAs for two separate companies).
I am sure it's related to domain/host configuration, as at one stage I saw the activity stream when I was changing some network settings, but it was only for a moment and I don't remember exactly what I have changed.
The only difference between the two, is that I hold reverse dns entries for the first one in my own DNS, the other one don't have them.
My network looks like this:
jira.company1.com > gateway > port 80 redirect > www gateway > virtual host redirect > server A port 8010
jira.company2.com > gateway > port 80 redirect > www gateway > virtual host redirect > server B port 8080
For my www gateway I use nginx, it's located on a separate virtual machine.
Both JIRA installations are standard.
Here are the entries for both virtual hosts:
server { listen 80; server_name jira.company1.com; location / { proxy_set_header Host $host; proxy_set_header X-Forwarded-Host $host; proxy_set_header X-Forwarded-Server $host; proxy_set_header X-Real-IP $remote_addr; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; proxy_pass http://10.10.0.6:8010/; } } server { listen 80; server_name jira.company2.com; location / { proxy_set_header Host $host; proxy_set_header X-Forwarded-Host $host; proxy_set_header X-Forwarded-Server $host; proxy_set_header X-Real-IP $remote_addr; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; proxy_pass http://10.10.0.8:8080/; } }
Gateway, www gateway, server A and server B are separate virtual machines.
On the JIRA installation, where activity stream does not work, calling:
http://jira.company2.com/activity?maxResults=10&os_authType=basic&title=undefined
returns proper data.
Could you please let me know, what else should I check?
I've search through the web and:
I just confirmed one thing. When I connect to my VPN, so I can actually access the server where jira is using its internal IP, I can see the activity stream, the moment I disconnect, the activity stream becomes empty.
