You are giving the commentMgr.create call parameters it is not written for. The issue, currentUser and boolean look right to me, but the error message saying "try grep or iterator" suggest that sourceFieldVal is some form of array, and your code on line 13 seems to be using it as such.
I absolutely do not understand anything you are telling me :->
Ok, but you need to understand this stuff if you're going to be writing scripts. I'd suggest an introduction to java or groovy course if you can find one.
Going back to the code, look at the last screenshot. Look at line 25 - it makes a call with four parameters. The error box is saying "I expected you to pass me an issue, a user, some text and a true/false flag, but you've passed me something else and I'm not written to handle" ("Overloading" is the word you'll see if you do a java course)
The error then goes on to try to suggest a fix - your IDE is looking at what you've passed in, and trying to suggest how to convert it to what the code needs. In this case, you've passed it a valid issue, a valid user, and a valid flag, but where it wanted a string, you've got something else. Because your IDE is suggesting the use of grep or an iterator, that suggests that you are passing it an array or list of some sort.
So, either go over that list to find the entry you want as a string, OR, go back to lines 12/13 where you appear to be creating an array instead of a string, and correct them so that they generate a string.
import com.atlassian.jira.ComponentAccessor
import com.atlassian.jira.issue.comments.CommentManager
import com.atlassian.jira.issue.CustomFieldManager
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.user.*;
ApplicationUser currentUser = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser();
CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager()
//Zusammenbau vom String für den Kommentar
Collection userCollection = (Collection) ComponentAccessor.getCustomFieldManager().getCustomFieldObject("customfield_10260").getValue(issue);
ApplicationUser[] userarray = (ApplicationUser[]) userCollection.toArray()
String sourceFieldVal = userarray[0].getDisplayName()
sourceFieldVal = "Hallo *" + sourceFieldVal + "* \
\n\ndie Hardware steht für dich zum Abverkauf bereit.\
\n\nBitte gib uns in diesem Ticket durch *Kauf bestätigen* Bescheid, ob du die Hardware kaufen möchtest.\
\nAlle relevanten Informationen zur Hardware kannst du oben im Ticket einsehen und sind ebenfalls im Kaufvertrag enthalten.\
\nDer Kaufbetrag wird vom Gehalt abgezogen.\
\n\nNach deiner Bestätigung, wird HR-Confidential den Kaufvertrag im Ticket hinterlegen. Bitte diesen Kaufvertrag ausdrucken, unterschreiben\
\nund bei Technical Services vorbeibringen.\
\nAlternativ kannst du den unterschriebenen Kaufvertrag einscannen und im Ticket hinterlegen.\
\n\nGrüße\
\nTechnical Services"
CommentManager commentMgr = ComponentAccessor.getCommentManager()
//Der wirkliche Kommentar
commentMgr.create(issue, currentUser, sourceFieldVal, true)This works for me. I get this comment in my issue:
Hallo Admin User
Bitte gib uns in diesem Ticket durch Kauf bestätigen Bescheid, ob du die Hardware kaufen möchtest.
Grüße
Technical Services
2016-05-04 11:28:49,293 http-bio-9001-exec-23 ERROR ad 688x164x1 d5peq8 172.16.177.197,10.0.0.63 /secure/CommentAssignIssue.jspa [scriptrunner.jira.workflow.ScriptWorkflowFunction] *************************************************************************************
2016-05-04 11:28:49,305 http-bio-9001-exec-23 ERROR ad 688x164x1 d5peq8 172.16.177.197,10.0.0.63 /secure/CommentAssignIssue.jspa [scriptrunner.jira.workflow.ScriptWorkflowFunction] Script function failed on issue: TS-7742, actionId: 21, file: /data/home/jira/groovyscripts/TS-HardwareSale-AbverkaufFreigeben.groovy
groovy.lang.MissingMethodException: No signature of method: java.util.ArrayList.getDisplayName() is applicable for argument types: () values: []
at TS-HardwareSale-AbverkaufFreigeben.run(TS-HardwareSale-AbverkaufFreigeben.groovy:11)
i take the same script and even restarted jira.
which version do you have installed?
i use the version 3.0.16
Ok, customfield_10900 is an user field (multi user)?
With a single user this works:
def sourceFieldVal = compManager.getCustomFieldManager().getCustomFieldObject("customfield_10900").getValue(issue).getDisplayName();
With multi user:
def sourceFieldVal = compManager.getCustomFieldManager().getCustomFieldObject("customfield_10900")[0].getValue(issue).getDisplayName();
I thought you use version 4.1.3.11?
your right version 4.1.3.11 i am confused sorry :->
ok your are right that is a multi user picker but it does not work
2016-05-04 11:42:57,901 http-bio-9001-exec-4 ERROR ad 702x259x1 d5peq8 172.16.177.197,10.0.0.63 /secure/CommentAssignIssue.jspa [scriptrunner.jira.workflow.ScriptWorkflowFunction] *************************************************************************************
2016-05-04 11:42:57,902 http-bio-9001-exec-4 ERROR ad 702x259x1 d5peq8 172.16.177.197,10.0.0.63 /secure/CommentAssignIssue.jspa [scriptrunner.jira.workflow.ScriptWorkflowFunction] Script function failed on issue: TS-7744, actionId: 21, file: /data/home/jira/groovyscripts/TS-HardwareSale-AbverkaufFreigeben.groovy
groovy.lang.MissingMethodException: No signature of method: com.atlassian.jira.issue.fields.CustomFieldImpl.getAt() is applicable for argument types: (java.lang.Integer) values: [0]
Possible solutions: getAt(java.lang.String), getId(), getName(), putAt(java.lang.String, java.lang.Object), wait(), grep()
at TS-HardwareSale-AbverkaufFreigeben.run(TS-HardwareSale-AbverkaufFreigeben.groovy:13)
do oyu think i need a restart every time a change the script?
nope
2016-05-04 11:47:35,158 http-bio-9001-exec-8 ERROR ad 707x440x1 alxor 172.16.177.197,10.0.0.63 /secure/CommentAssignIssue.jspa [scriptrunner.jira.workflow.ScriptWorkflowFunction] *************************************************************************************
2016-05-04 11:47:35,159 http-bio-9001-exec-8 ERROR ad 707x440x1 alxor 172.16.177.197,10.0.0.63 /secure/CommentAssignIssue.jspa [scriptrunner.jira.workflow.ScriptWorkflowFunction] Script function failed on issue: TS-7745, actionId: 21, file: /data/home/jira/groovyscripts/TS-HardwareSale-AbverkaufFreigeben.groovy
I updated code in my post above.
Please try with componentaccessor and new api.
2016-05-04 12:20:33,896 http-bio-9001-exec-1 ERROR ad 740x557x1 116bn5x 172.16.177.197,10.0.0.63 /secure/CommentAssignIssue.jspa [scriptrunner.jira.workflow.ScriptWorkflowFunction] *************************************************************************************
2016-05-04 12:20:33,896 http-bio-9001-exec-1 ERROR ad 740x557x1 116bn5x 172.16.177.197,10.0.0.63 /secure/CommentAssignIssue.jspa [scriptrunner.jira.workflow.ScriptWorkflowFunction] Script function failed on issue: TS-7746, actionId: 21, file: /data/home/jira/groovyscripts/TS-HardwareSale-AbverkaufFreigeben.groovy
org.codehaus.groovy.runtime.typehandling.GroovyCastException: Cannot cast object 'ad:1' with class 'com.atlassian.jira.user.BridgedDirectoryUser' to class 'com.atlassian.jira.user.ApplicationUser'
at TS-HardwareSale-AbverkaufFreigeben.run(TS-HardwareSale-AbverkaufFreigeben.groovy:7)
i dont know why but this works
import com.atlassian.jira.ComponentManager
ComponentManager compManager = ComponentManager.getInstance()
ApplicationUser currentUser = ComponentAccessor.getJiraAuthenticationContext().getUser();
CustomFieldManager customFieldManager = compManager.getCustomFieldManager()
sourceFieldVal = ""+issue.getCustomFieldValue(compManager.getCustomFieldManager().getCustomFieldObject("customfield_10900")).displayName
sourceFieldVal = sourceFieldVal[1..-2]
sourceFieldVal = "Hallo *" + sourceFieldVal + "*\
\n\nGrü▒~_e\
CommentManager commentMgr = compManager.getCommentManager()
commentMgr = (CommentManager) compManager.getComponentInstanceOfType(CommentManager.class)
em getting this error while executing the script .java.lang.NullPointerException: Cannot invoke method getCustomFieldValue() on null object
import com.atlassian.jira.ComponentManager;
import com.atlassian.jira.issue.CustomFieldManager;
import com.atlassian.jira.issue.fields.CustomField;
import com.atlassian.jira.issue.IssueManager;
import com.atlassian.jira.event.issue.field.CustomFieldUpdatedEvent;
import com.atlassian.jira.issue.Issue;
def projectComponentManager = ComponentAccessor.getProjectComponentManager()
MutableIssue issue = ComponentAccessor.getIssueManager().getIssueObject("issue key")
def issue = ComponentAccessor.getIssueManager().getIssueByCurrentKey("");
def userUtil = ComponentAccessor.getUserUtil()
def issueManager = ComponentAccessor.getIssueManager()
def cField = customFieldManager.getCustomFieldObject("customfield_10604")
def cFieldValue = issue.getCustomFieldValue(cField).toString()
userUtil.createUserNoNotification(cFieldValue,"",cFieldValue,cFieldValue)
def groupManager = ComponentAccessor.getGroupManager()
def user = userUtil.getUserByName(cFieldValue)
def group = groupManager.getGroup("BM")
groupManager.addUserToGroup(user,group)
Read https://scriptrunner.adaptavist.com/latest/jira/releases/UpgradingToJira7.html and https://scriptrunner.adaptavist.com/latest/jira/#_providing_type_information
Also as people say, the context where you are running stuff defines what is available, eg whether issue is there or not.
ok that is gone i am not a expert in groovy there still errors
Where do you try to execute this script?
In a transition? In a listener? What's your context?
I think you try to execute this code in the "Script console". But there is no object "issue". On which issue, you want to add the comment? On all issues? On an issue? On an issue using one transition in a workflow?
For one issue paste this to line 10:
def issue = ComponentManager.getIssueManager().getIssueObject("ISSUE-123");
So issue is defined and you will add your comment to ISSUE-123.
If you will add the comment on an issue using one transition, you will have to add the code in a post function. And there "issue" will be predefined.
hello robin
the script will be executed when you use a transition.it will paste a comment as the current user.
i use the script console to check the the syntax.
Then the syntax should be okay with the "def" in front of sourceFieldVal.
this is the error on catalin.out when a execute the transition where the script should be executed
2016-05-04 08:44:13,144 http-bio-9001-exec-16 ERROR ad 524x8689x1 xh1b52 172.16.177.197,10.0.0.63 /secure/CommentAssignIssue.jspa [scriptrunner.jira.workflow.ScriptWorkflowFunction] Script function failed on issue: TS-7732, actionId: 21, file: /data/home/jira/groovyscripts/TS-HardwareSale-AbverkaufFreigeben.groovy
java.lang.NullPointerException: Cannot get property 'displayName' on null object
at TS-HardwareSale-AbverkaufFreigeben.run(TS-HardwareSale-AbverkaufFreigeben.groovy:12)
Try:
def sourceFieldVal = ComponentManager.getCustomFieldManager().getCustomFieldObject("customfield_10900").getValue(issue);
now this error occurs:
2016-05-04 09:27:31,941 http-bio-9001-exec-8 ERROR ad 567x8759x1 xh1b52 172.16.177.197,10.0.0.63 /secure/CommentAssignIssue.jspa [scriptrunner.jira.workflow.ScriptWorkflowFunction] Script function failed on issue: TS-7734, actionId: 21, file: /data/home/jira/groovyscripts/TS-HardwareSale-AbverkaufFreigeben.groovy
groovy.lang.MissingMethodException: No signature of method: static com.atlassian.jira.ComponentManager.getCustomFieldManager() is applicable for argument types: () values: []
Possible solutions: getCustomFieldManager()
Sorry.
compManager.getCustomFieldManager().getCustomFieldObject("customfield_10900").getValue(issue);
you do not have to apologize.
2016-05-04 09:34:28,315 http-bio-9001-exec-10 ERROR ad 574x8865x1 xh1b52 172.16.177.197,10.0.0.63 /secure/CommentAssignIssue.jspa [scriptrunner.jira.workflow.ScriptWorkflowFunction] *************************************************************************************
2016-05-04 09:34:28,316 http-bio-9001-exec-10 ERROR ad 574x8865x1 xh1b52 172.16.177.197,10.0.0.63 /secure/CommentAssignIssue.jspa [scriptrunner.jira.workflow.ScriptWorkflowFunction] Script function failed on issue: TS-7737, actionId: 21, file: /data/home/jira/groovyscripts/TS-HardwareSale-AbverkaufFreigeben.groovy
java.lang.NullPointerException: Cannot invoke method getAt() on null object
at TS-HardwareSale-AbverkaufFreigeben.run(TS-HardwareSale-AbverkaufFreigeben.groovy:15)
Can you add this print after Line 12?
System.out.println("DEBUG Scriptrunner " + sourceFieldVal)
Is there a value in customfield_10900?
You will find the output in /{jira-application-dir}/logs/catalina.out
Or you can try the code in Script Console with
def issue = ComponentManager.getIssueManager().getIssueObject("TS-7734")in line 10.
that field is a userpicker.
i added System.out.println("DEBUG Scriptrunner " + sourceFieldVal)
2016-05-04 10:55:07,684 http-bio-9001-exec-16 ERROR ad 655x8962x1 xh1b52 172.16.177.197,10.0.0.63 /secure/CommentAssignIssue.jspa [scriptrunner.jira.workflow.ScriptWorkflowFunction] Script function failed on issue: TS-7739, actionId: 21, file: /data/home/jira/groovyscripts/TS-HardwareSale-AbverkaufFreigeben.groovy
groovy.lang.MissingPropertyException: No such property: sourceFieldVal for class: TS-HardwareSale-AbverkaufFreigeben
at TS-HardwareSale-AbverkaufFreigeben.run(TS-HardwareSale-AbverkaufFreigeben.groovy:10)
2016-05-04 10:58:45,376 http-bio-9001-exec-19 ERROR ad 658x8996x3 xh1b52 172.16.177.197,10.0.0.63 /secure/CommentAssignIssue.jspa [scriptrunner.jira.workflow.ScriptWorkflowFunction] *************************************************************************************
2016-05-04 10:58:45,376 http-bio-9001-exec-19 ERROR ad 658x8996x3 xh1b52 172.16.177.197,10.0.0.63 /secure/CommentAssignIssue.jspa [scriptrunner.jira.workflow.ScriptWorkflowFunction] Script function failed on issue: TS-7740, actionId: 21, file: /data/home/jira/groovyscripts/TS-HardwareSale-AbverkaufFreigeben.groovy
org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed:
file:/data/home/jira/groovyscripts/TS-HardwareSale-AbverkaufFreigeben.groovy: 17: expecting EOF, found 'DEBUG' @ line 17, column 21.
1 error
Nonono. The System.out please after line 12. You use the sourceFieldVal there. And it's just defined in Line 12.
Can you paste your whole code here in a code macro?
So I can change and you just have to paste in Script Console.
2016-05-04 11:05:36,921 http-bio-9001-exec-20 ERROR ad 665x9035x1 xh1b52 172.16.177.197,10.0.0.63 /secure/CommentAssignIssue.jspa [scriptrunner.jira.workflow.ScriptWorkflowFunction] *************************
2016-05-04 11:05:36,922 http-bio-9001-exec-20 ERROR ad 665x9035x1 xh1b52 172.16.177.197,10.0.0.63 /secure/CommentAssignIssue.jspa [scriptrunner.jira.workflow.ScriptWorkflowFunction] Script function failed on
1 import com.atlassian.jira.ComponentManager
2 import com.atlassian.jira.issue.comments.CommentManager
3 import com.atlassian.jira.issue.CustomFieldManager
4 import com.atlassian.jira.component.ComponentAccessor;
5 import com.atlassian.jira.user.*;
6
7 ComponentManager compManager = ComponentManager.getInstance()
8 ApplicationUser currentUser = ComponentAccessor.getJiraAuthenticationContext().getUser();
9 CustomFieldManager customFieldManager = compManager.getCustomFieldManager()
10
11 //Zusammenbau vom String für den Kommentar
12 def sourceFieldVal = ComponentManager.getCustomFieldManager().getCustomFieldObject("customfield_10900").getValue(issue);
13 System.out.println("DEBUG Scriptrunner " + sourceFieldVal)
14 sourceFieldVal = sourceFieldVal[1..-2]
15
16 sourceFieldVal = "Hallo *" + sourceFieldVal + "* \
17 \n\ndie Hardware steht für dich zum Abverkauf bereit.\
18 \n\nBitte gib uns in diesem Ticket durch *Kauf bestätigen* Bescheid, ob du die Hardware kaufen möchtest.\
19 \nAlle relevanten Informationen zur Hardware kannst du oben im Ticket einsehen und sind ebenfalls im Kaufvertrag enthalten.\
20 \nDer Kaufbetrag wird vom Gehalt abgezogen.\
21 \n\nNach deiner Bestätigung, wird HR-Confidential den Kaufvertrag im Ticket hinterlegen. Bitte diesen Kaufvertrag ausdrucken, unterschreiben\
22 \nund bei Technical Services vorbeibringen.\
23 \nAlternativ kannst du den unterschriebenen Kaufvertrag einscannen und im Ticket hinterlegen.\
24 \n\nGrü▒~_e\
25 \nTechnical Services"
26
27 CommentManager commentMgr = compManager.getCommentManager()
28 commentMgr = (CommentManager) compManager.getComponentInstanceOfType(CommentManager.class)
29 //Der wirkliche Kommentar
30 commentMgr.create(issue, currentUser, sourceFieldVal, true)
At a glance, the sourceFieldVal variables should have "def" in front of them
