Adaptivist ScriptRunner scripts and objects not working with Jira 8.2.3
KL Kumar
I followed Part 1 and Part 2 to create my custom plugin for scriptrunner scripts and it was working great until migrating to Jira 8.2.3. But after migration, I have updated my AMPS version to 8.0.0.
The maven-jira-plugin has been changed to jira-maven-plugin in AMPS from v8.0.0 and later.
Now when I build my custom Scriptrunner plugin, the parent pom is referring to the earlier artifacts of jira-maven-plugin and so the build is failing with the below error (maven-jira-plugin:8.0.2 or one of its dependencies could not be resolved)
[INFO] Scanning for projects...
[WARNING] The POM for com.atlassian.maven.plugins:maven-jira-plugin:jar:8.0.2
is missing, no dependency information available
[ERROR] [ERROR] Some problems were encountered while processing the POMs:
[ERROR] Unresolveable build extension:
Plugin com.atlassian.maven.plugins:maven-jira-plugin:8.0.2
or one of its dependencies could not be resolved:
Failure to find com.atlassian.maven.plugins:maven-jira-plugin:jar:8.0.2
in https://maven.atlassian.com/repository/public was cached in the
local repository, resolution will not be reattempted until the update
interval of atlassian-public has elapsed or updates are forced @
The parent pom which I am using is
<parent>
<groupId>com.adaptavist.pom</groupId>
<artifactId>scriptrunner-jira-standard</artifactId>
<version>13</version>
<relativePath />
</parent>
The jira-maven-plugin which I am using is
<plugin>
<groupId>com.atlassian.maven.plugins</groupId>
<artifactId>jira-maven-plugin</artifactId>
<version>8.0.0</version>
<extensions>true</extensions>
<configuration>
<jvmArgs>-Xms512m -Xmx1g -XX:MaxPermSize=1g -XX:-UseGCOverheadLimit
-server</jvmArgs>
<productVersion>${jira.version}</productVersion>
<productDataVersion>${jira.version}</productDataVersion>
</configuration>
@Alexey Matveev
Could you please throw some light on this and suggest a solution? Thanks in advance!
Kumar
KL Kumar
Now I am able to build the custom plugin jar with my scriptrunner scripts. But now, the paths of these scripts are not able to detect in Workflow validators/conditions/postfunctions. I get the error "path not found".
Here's my pom
<?xml version="1.0" encoding="UTF-8"?>
<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/maven-v4_0_0.xsd">
<modelVersion>4.0.0</modelVersion>
<groupId>com.example.scriptrunner</groupId>
<artifactId>example-scriptrunner-plugin</artifactId>
<version>1.2.0-SNAPSHOT</version>
<organization>
<name>Example</name>
<url>http://www.example.com/</url>
</organization>
<!-- <packaging>atlassian-plugin</packaging> -->
<name>example-scriptrunner-plugin</name>
<description>This is the com.example.scriptrunner:example-scriptrunner-plugin plugin for Atlassian JIRA.</description>
<scm>
<developerConnection>scm:git:ssh://git@stash.adaptavist.com:7999/sr/scriptrunner-samples.git</developerConnection>
<tag>HEAD</tag>
</scm>
<dependencies>
<dependency>
<groupId>com.onresolve.jira.groovy</groupId>
<artifactId>groovyrunner</artifactId>
<version>5.5.9.1-jira8</version>
<scope>provided</scope>
<exclusions>
<exclusion>
<groupId>com.onresolve.scriptrunner.platform</groupId>
<artifactId>scriptrunner-test-libraries-jira</artifactId>
</exclusion>
<exclusion>
<groupId>jndi</groupId>
<artifactId>jndi</artifactId>
</exclusion>
<exclusion>
<groupId>jta</groupId>
<artifactId>jta</artifactId>
</exclusion>
<exclusion>
<groupId>is.origo.jira</groupId>
<artifactId>tempo-plugin</artifactId>
</exclusion>
<exclusion>
<groupId>com.tempoplugin</groupId>
<artifactId>tempo-core</artifactId>
</exclusion>
<exclusion>
<groupId>groovyrunner</groupId>
<artifactId>test</artifactId>
</exclusion>
<exclusion>
<groupId>com.atlassian.plugin.automation</groupId>
<artifactId>automation-api</artifactId>
</exclusion>
</exclusions>
</dependency>
<dependency>
<groupId>javax.inject</groupId>
<artifactId>javax.inject</artifactId>
<version>1</version>
</dependency>
<dependency>
<groupId>org.codehaus.jackson</groupId>
<artifactId>jackson-core-asl</artifactId>
<version>1.9.13</version>
</dependency>
<dependency>
<artifactId>jackson-mapper-asl</artifactId>
</dependency>
<!-- Spring -->
<dependency>
<groupId>org.springframework</groupId>
<artifactId>spring-beans</artifactId>
<version>5.1.5.RELEASE</version>
</dependency>
<!-- Common Atlassian libraries -->
<dependency>
<groupId>com.atlassian.sal</groupId>
<artifactId>sal-api</artifactId>
<version>4.0.0</version>
</dependency>
</dependencies>
<build>
<plugins>
<plugin>
<version>${amps.version}</version>
<configuration>
<jvmArgs>-Xms512M -Xmx1g</jvmArgs>
<enableQuickReload>true</enableQuickReload>
<enableFastdev>false</enableFastdev>
<applications>
<application>
<applicationKey>jira-software</applicationKey>
<version>${jira.version}</version>
</application>
</applications>
<instructions>
<Atlassian-Plugin-Key>${atlassian.plugin.key}</Atlassian-Plugin-Key>
<Import-Package>
org.springframework.osgi.*;resolution:="optional",
org.eclipse.gemini.blueprint.*;resolution:="optional",
</Import-Package>
<Spring-Context>*</Spring-Context>
</instructions>
</configuration>
</plugin>
<plugin>
<groupId>org.codehaus.gmavenplus</groupId>
<artifactId>gmavenplus-plugin</artifactId>
<version>1.6</version>
<executions>
<execution>
<goals>
<goal>addSources</goal>
</goals>
</execution>
</executions>
<configuration>
<sources>
<source>
<directory>${project.basedir}/src/main/groovy</directory>
<includes>
<include>**/*.groovy</include>
</includes>
</source>
<source>
<directory>${project.basedir}/src/main/resources</directory>
<includes>
</includes>
</source>
</sources>
<testSources>
<testSource>
<directory>${project.basedir}/src/test/groovy</directory>
<includes>
</includes>
</testSource>
<testSource>
<directory>${project.basedir}/src/test/resources</directory>
<includes>
</includes>
</testSource>
</testSources>
</configuration>
<dependencies>
<dependency>
<groupId>org.codehaus.groovy</groupId>
<artifactId>groovy-all</artifactId>
<version>${groovy.version}
</version>
<scope>runtime</scope>
</dependency>
</dependencies>
</plugin>
</plugins>
</build>
<properties>
<jira.version>8.2.4</jira.version>
<amps.version>8.0.2</amps.version>
<quick.reload.version>3.0.0</quick.reload.version>
<maven.compiler.source>1.8</maven.compiler.source>
<maven.compiler.target>1.8</maven.compiler.target>
<maven.test.skip>true</maven.test.skip>
<project.build.sourceEncoding>UTF-8</project.build.sourceEncoding>
<atlassian.spring.scanner.version>2.1.10</atlassian.spring.scanner.version>
<atlassian.plugin.key>${project.groupId}.${project.artifactId}</atlassian.plugin.key>
<java.version>1.8</java.version>
<groovy.version>2.4.15</groovy.version>
</properties>
<repositories>
<!-- This is required to find the parent pom and ScriptRunner dependencies -->
<repository>
<id>adaptavist-external</id>
<url>https://nexus.adaptavist.com/content/repositories/external</url>
<snapshots>
<enabled>false</enabled>
</snapshots>
<releases>
<enabled>true</enabled>
<checksumPolicy>fail</checksumPolicy>
</releases>
</repository>
</repositories>
</project>
Soeren Rumpf May 13, 2020
Did you find a solution for your problem?
