Sign up Log in
Add Description Field to Notification Emails
JSzymik
How do I add the Description field of a newly created ticket into the body of the notification emails when an issue is created in the Jira Service Desk?
Raynard Rhodes
November 15, 2018
It depends on which notification you want to send out.
If you go to project settings > Customer Notifications you will be able to edit what these notifications look like based on an event.
When you choose a rule, inside it will have an "insert variable" option that will have "issue description" or you can manually enter ${issue.description}.
JSzymik
Here's what I've tried in pictures:
2018-11-15 12_53_23-Window.jpg2018-11-15 12_48_27-Window.jpg2018-11-15 12_44_30-Window.jpg
JSzymik
Thank you for your quick follow-up on my questions!
Raynard Rhodes
November 15, 2018
It seems like you're updating the portion that will be in all issues regardless. You want to scroll down a little bit and add the description to individual events.
Request Created, Public Comment Added, etc.
Like JSzymik likes this
Raynard Rhodes
November 15, 2018
That also looks like an uneditable. Issue Assigned is under "Notification" and not "Customer Notification" it appears to only give the option to email certain individuals but not modify the content of that email.
I can look into a bit more though.
JSzymik
That's what I've found also.
JSzymik
I thought I was overlooking something!
Like Raynard Rhodes likes this
JSzymik
@Raynard Rhodes I created a ticket (PSCLOUD-13642) and was told this enhancement had already been suggested but would not be implemented in the near future, which is a bummer because it would be very helpful in triaging our JSD tickets without having to log in to Jira  Unfortunately it will not be looked at any further.  Reference JRACLOUD-7266 for more information.
This is the first time in five years I've been disappointed with Atlassian.
Thank you again for your help!
Like # people like this
