IMO, the above seems fine. However, the ask from my team is to have separate steps for testing between the environments they typically test in. Perhaps something like, In Review >> Resolved (if peers approve) >> In QA Review (Dev) >> In QA Review (QA).
There are times when QA can test in dev but then are blocked from continuing their testing in QA due to some issue on that environment.
We'd like to add a new status to the BRUC and QM projects.
The 'Dev Testing' status would come after Ready For Testing/In QA and precede QA Testing.
JIRA supports that.
I think you might have posted this in the wrong place. It looks like a change request for your administrators, but this is a public forum for end-users - we have no admin rights over your system (unless one of your admins is here). If my guess is correct, then could you talk to your admins? If I am wrong and you are looking for community support, then could you explain where you are stuck?
