Hi all,
Anyone succeeded in accomplishing the following without using any Jira add-ons?
1. Add a new project field (attribute), similar to Key or Description?
2. Make the project Description a mandatory field at project creation?
Thank you all!
Hi @Emanuel Jianu,
Unfortunately, I have not found any documentation regarding the customisation of the project creation process. I found an add-on that seems to adhere to your requirements however.
Hope this helps
The only way to do it without add-ons is to hack the core of Jira, effectively implementing what an add-on would do in the core.
An add-on is easier, faster and safer than that, plus it leaves you supported if something goes wrong (Atlassian don't technically support add-ons, but if you have a problem, you can temporarily remove add-ons to put it back in a supported state)
