Add a value in Components part of a project
Deleted user June 9, 2017 edited
Hi guys,
I am trying to develop a groovy script (post function) which add a value in Components part of a Project.
I  have the following error :
No signature of method: com.atlassian.jira.ComponentManager.getProjectComponentManager() is applicable for argument types: () values: []
create(String name, String description, String lead, long assigneeType, Long projectId)
 I think the problem come from the fourth parameter, I have put 0 because I don't know how to get the right value.
Here is my code :
import com.atlassian.jira.issue.CustomFieldManager
import com.atlassian.jira.issue.IssueManager
import com.atlassian.jira.issue.customfields.manager.OptionsManager
import com.atlassian.jira.issue.customfields.option.Option
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder
import com.atlassian.jira.ComponentManager
import com.atlassian.jira.issue.ModifiedValue
import com.atlassian.jira.bc.project.component.ProjectComponent
import  com.atlassian.jira.bc.project.component.ProjectComponentManager
OptionsManager optionsManager = ComponentAccessor.getOptionsManager()
CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager()
ComponentManager componentManager = ComponentManager.getInstance()
//MutableIssue issue = issue
def issue = ComponentAccessor.getIssueManager().getIssueObject("CTY-213")
def userProjectId = 13900
def component = componentManager.getProjectComponentManager().create("test toto","description","leadtoto",0,userProjectId)
Deleted user June 12, 2017
def projectComponentManager = ComponentAccessor.getProjectComponentManager()
//def issue = ComponentAccessor.getIssueManager().getIssueObject("CTY-213")
CustomField newApplication = customFieldManager.getCustomFieldObject((long)20210) //PP et P
def cfValue = issue.getCustomFieldValue(newApplication).toString()
CustomField mainOwner = customFieldManager.getCustomFieldObject((long)20206) //PP et P
def cfValueMainOwner = issue.getCustomFieldValue(mainOwner).toString()
String []name=cfValueMainOwner.split("\\(")
def component = projectComponentManager.create(cfValue,"",name[0],1,userProjectId)
return component
Tom Lister
FYI
Run script to add Component to multiple projects
/* new component */
String componentName = "EE"
String description = "desc"
long projectId = 0
ProjectComponentManager pComMgr = ComponentAccessor.getProjectComponentManager()
ProjectComponent component
def projectManager = ComponentAccessor.getProjectManager()
String[] projects = ["CSSO", "SEUK", "SEBN", "SEP", "SESA", "SEG", "PC", "SEAG", "SESG", "SEI", "SEF", "SEPOL",
"SEGR", "SENA", "SEROM", "SEB", "SEH", "SECZ", "SEAD"]
projects.each() {String projectName ->
     projectId = projectManager.getProjectByCurrentKey(projectName).getId()
     component = pComMgr.create(componentName, description, null , 0, projectId)
Dusty Brossart
Hello @Tom Lister
Is there a way to specify all projects or all projects within a particular category without providing the project key?
-Dusty
Tom Lister
Hi
You  can loop through projects by category like this.
import com.atlassian.jira.project.Project
import com.atlassian.jira.project.ProjectManager
import com.atlassian.jira.util.SimpleErrorCollection
String [] categories = ["WSC", "P6", "BOLD"]
// SSO1
ProjectManager pMgr = ComponentAccessor.getProjectManager()
//def proj = pMgr.getProjectObjects()
Collection<String> actorNames
categories.each() {category ->
def p6 = pMgr.getProjectCategoryObjectByName(category)
def proj = pMgr.getProjectObjectsFromProjectCategory(p6.getId())
      proj.each() {Project p ->
     // blah
Tom Lister
If you have Scriptrunner you can try this to copy components between projects
import org.apache.log4j.Logger
import com.onresolve.scriptrunner.parameters.annotation.ProjectPicker
def logit = Logger.getLogger("com.cheil.eu.logging")
long projectId = 0
@ProjectPicker(label = "Source Project", description = "Select project to copy Components from")
Project source
@ProjectPicker(label = "Target Project", description = "Select project to copy Components to")
Project target
Collection<ProjectComponent> comps = pComMgr.findAllForProject(source.getId())
comps.each() { ProjectComponent component ->
def test = pComMgr.findByComponentName(projectId, component.getName())
if (!test) {
def comp = pComMgr.create(component.getName(), null, null , 0, target.getId())
logit.info("Add " + component.getName() + " to " + target.getName())
} else {
logit.info(component.getName() + " already exists in " + target.getName())
Shame on me, the function getProjectComponentManager seems not existing anymore. I have to find another function to do what I want. Any ideas ?
Jackson Farnsworth
October 6, 2017
Strange, it still exists in JIRA 7.3.6
ComponentAccessor Documentation
Help us plant more trees
