Add columns to issue links view
Laura Bantug December 12, 2012
I would like Fix Version of the linked issue to be visible on the "linked issues" view of a JIRA ticket. Is this customization available in any version of JIRA and how would you do it?
Jobin Kuruvilla [Adaptavist]
December 12, 2012
You can't do it via configuration. You will have to modify a bundled plugin to add more fields.
5 votes
James Brown
October 19, 2017
It has been a year since the last comment. Does Atlassian plan on making allowing users to customize the fields displayed in the Issue Links on the View Screen?
Christine Diamond
Indicates "Answer Accepted" next to a statement that "it can't be done," which is not a satisfactory answer. What is the point of seeing Status without FixVersion? Please add the function to add fields to this section.
Sarit Cohen
September 22, 2016
Hello All
There is any updated on this issue since 2013?
I'd like to see version, Assignee and status
Hung Nguyen
I used Issue Matrix plugin for this
Ingrid Smidt
August 19, 2019
Still needing this fix
max April 24, 2019
No update for this ?
Dang Thi Thuy Tien
July 9, 2020 edited
You can use the plugin to add new column Smart Panel can help.
The document about how to config here: https://mgm-tp.atlassian.net/wiki/spaces/IP2/overview
You can modify with Smart System Panel: https://mgm-tp.atlassian.net/wiki/spaces/IP2/pages/612335823/Smart+System+Panel
Andy Cleff
February 4, 2013
Anyone have the specific mods need for the JIRA Linker Plugin to add other columns to the Issue Links area?
For example, code to change the columns displayed on the Sub Tasks section of an issue ticket via jira-config.properties looks like this:
# Adds issuekey to the default list of fields to show
jira.table.cols.subtasks is set to issuekey, issuetype, status, assignee, progress
If not possible in default config, any suggestions for plugins that can do this?
December 12, 2012
Well, as I said, it is already rendered using a bundled plugin in JIRA. You will have to modify that plugin. Can't change it with another plugin :)
http://www.j-tricks.com/1/post/2012/05/modifying-atlassian-bundled-plugins.html explains some details about modifying bundled plugins.
