Add custom field in Log Work Screen
keyur
Can any one help me to add custom field in work log screen? I just need only one field to serve purpose of time tracking & Reporting.
It would be great help, if we have work around except costly Add-on.
Thank You,
Keyur Shah
Ryan Pelletier August 17, 2015
Unfortunately, no, it isn't possible to do via configuration in jira. However...
I was able to come up with a hack to solve this by creating a plugin and modifying the logwork.jsp file to add new fields.I used the Servlet-Filter Plugin module to grab the new parameters from the request, then basically I wrote them to a database...not the JIRA one though.
Did you come up with a solution?
Paulo Hennig
July 24, 2015
Hello Keyur,
Sorry to say that this is currently not possible, but we have this open suggestion: https://jira.atlassian.com/browse/JRA-1780 that I would suggest you to vote on it and set yourself as a watcher for future updates.
