Add custom field to JIRA e-mails
Georgiy Senenkov
I would like to add custom field to JIRA 5.1 html notifications e-mail. I found that I need to modify velocity templates , e.g. issuecreated.vm. In that file i found references to the include folder to specify which fields to include.
Could you please advise how to make .vm file for custom field to include it into issuecreated.vm?
Thank you in advance.
Regards, Georgiy
C_ Faysal
December 4, 2012
hi
lets assume your customfield has id 11800
in your your_new.vm file put this info:
#disable_html_escaping()
#if ($issue.getCustomFieldValue("customfield_11800"))
<tr valign="top">
    <td style="color:${textColour};font-family:${textFontFamily};font-size:${textSize};padding:0 10px 10px 0;white-space:nowrap;">
        <strong style="font-weight:normal;color:${textSubtleColour};">#text("NAME OF YOUR FIELD"):</strong>
    </td>
    <td style="color:${textColour};font-family:${textFontFamily};font-size:${textSize};padding:0 0 10px 0;width:100%;">
    </td>
#end
</tr>
then include it in issuecreated.vm like this:
$stringUtils.leftPad($issue.getCustomField("customfield_11800").name, $padSize): $issue.getCustomFieldValue("customfield_11800")
#end
C_ Faysal
December 4, 2012
this will make your field appear in emails only if it has values...
Like Carolina Rodrigues likes this
Georgiy Senenkov
I made new.vm file as you advised and then included it into issuecreated.vm file as
#parse("templates/email/html/includes/fields/new.vm")
and it works as needed :)
Thank you very much!
C_ Faysal
December 4, 2012
glad i could help...
Christian Czaia [Decadis AG]
May 28, 2013
Shouldn't the closing</tr> tag be positioned before the #end
Cheers Christian
C_ Faysal
May 28, 2013
oh you're right. just for optical satisfaction...but it works like this (i took it from current working instance)
ok i just re-checked with an out-of-the-box file that came with jira..
cat atlassian-jira/WEB-INF/classes/templates/email/html/includes/fields/reporter.vm
&lt;tr valign="top"&gt;
    &lt;td style="color:${textColour};font-family:${textFontFamily};font-size:${textSize};padding:0 10px 10px 0;white-space:nowrap;"&gt;
        &lt;strong style="font-weight:normal;color:${textSubtleColour};"&gt;#text("issue.field.reporter"):&lt;/strong&gt;
    &lt;/td&gt;
    &lt;td style="color:${textColour};font-family:${textFontFamily};font-size:${textSize};padding:0 0 10px 0;width:100%;"&gt;
        #if ($issue.reporterId)
            #authorlinkkey($issue.reporterId $linkstyle)
        #else
            #text("common.concepts.no.reporter")
        #end
    &lt;/td&gt;
&lt;/tr&gt;
Will
I am encountering a problem with including custom fields in e-mail templates. The template does not appear to evaluate the getCustomFieldValue it simply output the raw code, see below. The custom field has a value for the issue I am sending the e-mail from. Is there a setting or other action needed to get the custom fields to work or is my code wrong? Any advice is appreciated. I am running JIRA 6.3.15 Code in template file: #if ($issue.getCustomFieldValue("customfield_10011")) $stringUtils.leftPad($issue.getCustomFieldObjectByName("customfield_10011").name, $padSize): $issue.getCustomFieldValue("customfield_10011") #end Participant: $issue.getCustomFieldValue("customfield_10011") Result in e-mail: Participant: $issue.getCustomFieldValue("customfield_10011")
pokalav
Hi Faysal,
     As you mentioned first, In which folder could i past that code can you clarify that i need priority_Hcp customfield is to add in email.
Thank you,
Venkatesh.
Sreenivasaraju P
December 4, 2012
You can create your own vm or templates,you can refer custom fields as below.
#set($fieldname=$customFieldManager.getCustomFieldObject("customfield_11100"))
$issue.getCustomFieldValue($fieldname)
Sameera Shaakunthala [inactive]
April 3, 2013
Is the following syntax OK?
#set($cf_downtime=$customFieldManager.getCustomFieldObjectsByName("Downtime").next())
$issue.getCustomFieldValue($cf_downtime)
Basically what I'm asking is, can we use getCustomFieldObjectsByName() function?
