I'm developing Jira Plugin, now my task is to insert custom read-only text field into my web-panel in issue view screen (like Zephyr add-on does, see screen)
I've read multiple answers, it seems, it is not officially supported but if desperately want to, one should either mangle with Jira Core code or rearrange field with JS. Anyway I'm determined to accomplish it with the second option.
Could you provide one example/tutorial (with code) how it can be done using JS (or without it) for one custom field displayed in the custom web-panel.
Any help would be greatly appreciated!
@Egor Erofeev you should check out the Atlassian Developer Community, which helps users who are developing plugins!
