Add default text to description failed while changing project
Shaikh Moiz
June 21, 2017 edited
I am about to change the blank description field to some default text.
When I set this field via Field initializer it is working for the first time. But as soon as I change the project from project dropdown this retains the previous text.
However I had set a condition to check project key and issue type in my script.
Am I missing something here ?
Below is code that I am refering.
Moiz
Shaikh Moiz
After changing the mapping solved the issue.
