I've been unable to find a method in the Jira 7 API allowing me to add groups to a security level. Any help would be much appreciated,
So I was actually able to accomplish this with the following code:
import com.atlassian.jira.issue.security.IssueSecuritySchemeManager
import com.atlassian.jira.scheme.SchemeEntity
def issueSecurityLevelManager = ComponentAccessor.getIssueSecurityLevelManager()
def issueSecuritySchemeManager = ComponentAccessor.getComponent(IssueSecuritySchemeManager)
def scheme = issueSecuritySchemeManager.getSchemeObject("scheme 1") //Name of scheme
def levels = issueSecurityLevelManager.getIssueSecurityLevels(scheme.id)
levels.each{
def entity = new SchemeEntity("group", "jira-users", it.id)
def gv = issueSecuritySchemeManager.getScheme(scheme.id)
issueSecuritySchemeManager.createSchemeEntity(gv, entity)
The above code takes a scheme, traverses all of its levels, and adds the "jira-user" group to each one. Now, I assume this isn't exactly what you'd like to happen in your instance, but, as I don't know your exact requirements, I figured it would be a good example. The biggest problem with the code in the above answers is this method here:
def gv = issueSecuritySchemeManager.getIssueSecurityLevelScheme(scheme.id)
As I'm sure you've found out, that method doesn't actually return a GenericValue, which is necessary for the "createSchemeEntity" method. I searched for quite some time looking for a way to make that method work, but I didn't have much luck so you may just have to use the deprecated method "getScheme" instead. But regardless, it should get the job done.
Best,
Aidan
So I've replaced "group" with "projectrole", but the role doesn't quite pop up. Instead of the security level gaining:
"Project Role (RoleName)"
It gets:
"Project Role"
Is there something special that you have to do with Roles to update it properly?
Never mind, did some more digging. The second argument has to be the Role ID (Long) in String form.
def entity = new SchemeEntity("projectrole", "10201", level.id)
Thank you. I tried and came close, but I did not see that inherited method to get the GenericValue Scheme in the doc.
And also the "recommended" method "issueSecuritySchemeManager.getIssueSecurityLevelScheme(scheme.id)" gives you an object of type "IssueSecurityLevelScheme", but there is no way of actually using that to create a SchemeEntity, because the only method I found needs a "GenericValue". And there also seems to be no way to get such a GenericValue from an object of type "IssueSecurityLevelScheme". So you have to basically build it yourself, which might be possible if I just knew what exactly the first constructor parameter is "EntityModel".
But yeah... I gave up and just used the "deprecated" method, which is way easier, as you demonstrated, unless I'm overlooking something.
Hi!
Need help with creating the the entity for user custom field value (multiuser customfield) , I tried
Works on Jira Server 8.10
Even I couldn't get closer than this - I give up for the moment :/ :
import com.atlassian.jira.issue.security.IssueSecurityTypeManager
import com.atlassian.jira.security.type.SecurityType
import com.atlassian.jira.issue.security.IssueSecurityLevelPermission
def group = ComponentAccessor.getGroupManager().getGroup ("jira-users")
def securityLevelManager = ComponentAccessor.getIssueSecurityLevelManager()
def issueSecuritySchemeManager = ComponentAccessor.getComponent(IssueSecuritySchemeManager.class)
def issueSecurityTypeManager = ComponentAccessor.getComponent(IssueSecurityTypeManager.class)
def issueSecurityTypes = issueSecurityTypeManager.getSchemeTypes()
def issueSecurityType = issueSecurityTypeManager.getSchemeTypes()["group"]
def issueSecurityLevelScheme = issueSecuritySchemeManager.getIssueSecurityLevelSchemes().find {
it.name == "Example Security Level"
def securityLevel = securityLevelManager.getIssueSecurityLevels(issueSecurityLevelScheme.id).find {
it.name == "Level 1"
From this point, following steps might give you a clue.
Shaakunthala
profiling flags up:
/secure/admin/AddIssueSecurity.jspa [c.a.util.profiling.UtilTimerStack] [15ms] - /jira/secure/admin/AddIssueSecurity.jspa
[14ms] - AddIssueSecurity.execute()
/secure/admin/EditIssueSecurities!default.jspa [c.a.util.profiling.UtilTimerStack] [90ms] - /jira/secure/admin/EditIssueSecurities!default.jspa
[0ms] - EditIssueSecurities.execute()
not sure what one would do with it though, api docs don't say much
Following solution works with JIRA 7.1.9: https://community.atlassian.com/t5/JIRA-questions/Groovy-to-automatically-add-a-few-hundreds-of-Security-levels-to/qaq-p/72941#U622517
I get the following error:
groovy.lang.MissingMethodException: No signature of method: static com.atlassian.jira.scheme.SchemeManager.createSchemeEntity() is applicable for argument types: (org.ofbiz.core.entity.GenericValue, com.atlassian.jira.scheme.SchemeEntity)
here's 95% of it, can't get the final statement to work, taken from https://community.atlassian.com/t5/JIRA-questions/Groovy-to-automatically-add-a-few-hundreds-of-Security-levels-to/qaq-p/72941
import com.atlassian.jira.scheme.SchemeManager
import org.ofbiz.core.entity.GenericValue
def scheme = issueSecuritySchemeManager.createSchemeObject("FRIDAY", "Issue security scheme for testing")
def level = issueSecurityLevelManager.createIssueSecurityLevel(scheme.id, "Private", "Group only")
def entity = new SchemeEntity("group", "jira-users", level.id)
doesn't work
for the above to work in 7.3.1 I need to supply a scheme of type GenericValue to createSchemeEntity(). I tried to cast but no luck:
IssueSecurityLevelScheme gv = issueSecuritySchemeManager.getIssueSecurityLevelScheme(issueSecurityScheme.id)
issueSecuritySchemeManager.createSchemeEntity(gv as GenericValue, entity)
org.codehaus.groovy.runtime.typehandling.GroovyCastException: Cannot cast object 'com.atlassian.jira.issue.security.IssueSecurityLevelScheme@59f1a670' with class 'com.atlassian.jira.issue.security.IssueSecurityLevelScheme' to class 'org.ofbiz.core.entity.GenericValue'
at Script253.run(Script253.groovy:25)
Can anybody assist?
Register Now
