Hi All
I can customise the JIRA Introduction message by going into the Administration -> System -> Editing the introduction field.
My requirement is to add a hyperlink to a certain piece of text to the introduction section.
How can i do that?
Rahul
Just add hyperlink as in HTML:
<a href="http://atlassian.com">Atlassian</a>
this works thanks :)
You should be able to use a regular HTML link:
<a href="url">link text</a>
This doesn't work in jira SD server. You need to use wiki markup as [your text|<url>]
