Add menu item to web-section of another plugin
AlexSav94 March 18, 2020
Is there any way to add drop-down menu item to web section of another plugin?
If i know key values of web-section element?
Jack [AppFox]
Assuming you're using Server/DC, you should be able to add to these web-sections using either:
  • a simple plugin, with the web-item in the atlassian-plugin.xml
  • the 'Script Fragments' feature of ScriptRunner
Learn more
