Add multiple componet to particular project
srinivasan radhakrishnan
April 25, 2013
Hi Committe,
I have added one componet to the particular project by using the below json file,
"name": "Component 1",
"description": "This is a JIRA component",
"leadUserName": "fred",
"assigneeType": "PROJECT_LEAD",
"isAssigneeTypeValid": false,
"project": "PXA"
I need to add 3 commponents like "componet 2","component 3","component 4" in by using the same json file.
i have tried this below,
"name": ["Component 2","component 3","component 4"],
"project": "PXA"
and i got the below issue,
How to solve this issue, please correct my json file structure.
Colin Goudie
April 25, 2013
Ah sorry, I see what you mean. If you're POSTing to that end point you need to POST 3 times. With different data. 1 POST = 1 Component
Colin Goudie
April 25, 2013
It would be more like
"project": "PXA"
"name": "Component 2",
"description": "This is a JIRA component 2",
"project": "PXA"
"name": "Component 3",
"description": "This is a JIRA component 3",
"project": "PXA"
April 25, 2013
Hi Colin Goudie,
I have used the given json file
"project": "PXA"
"project": "PXA"
"project": "PXA"
but i got this issue,
{"errorMessages":["Can not deserialize instance of com.atlassian.jira.rest.v2.issue.component.ComponentBean out of START_ARRAY token\n at [Source: org.apache.catalina.connector.CoyoteInputStream@188f899; line: 1, column: 1]"]}
Chaithra N
April 25, 2013
Read the story
