Hi All
I trying to create one project in JIRA through API by ASp.net Application. Below i giving my code. I not getting any exception. But Not adding project to JIRA. Where i doing mistake?
string url = "https://actjira.atlassian.net/rest/api/2/project";
HttpWebRequest request = WebRequest.Create(url) as HttpWebRequest;
request.ContentType = "application/json";
request.Method = "POST";
string base64Credentials = GetEncodedCredentials();
request.Headers.Add("Authorization", "Basic " + base64Credentials);
request.ContentLength = data.Length;
try
using (var reqStream = request.GetRequestStream())
using (StreamWriter writer1 = new StreamWriter(reqStream))
writer1.Write(data);
catch (Exception e1)
throw e1;// error handling code
private string GetEncodedCredentials()
string mergedCredentials = string.Format("{0}:{1}", "username", "password");
byte[] byteCredentials = UTF8Encoding.UTF8.GetBytes(mergedCredentials);
return Convert.ToBase64String(byteCredentials);
I reffered below url
https://docs.atlassian.com/jira/REST/latest/#api/2/project-createProject and Passing data
You appear to be calling the create function without giving it any data.
Hi Nic Brough Thanks for your response. I passing data in same format below mentioned url. I not able to give here that format here i getting error when i click button https://docs.atlassian.com/jira/REST/latest/#api/2/project-createProject string data= "\"fields\": { \"project\": { \"id\": \"TJI\" }, \"description\": \"Hellow why doesn't this work\", \"summary\": \"REST ye merry gentlemen.\", \"issuetype\": { \"name\": \"Bug\" } } ";
The fields in there are for issue creation/update, not project. Try sending it the correct data format, as listed in the link you've given.
string data = "{\"key\": \"EX1\",\"name\": \"Example1\",\"projectTypeKey\": \"software\",\"description\": \"Example Project description\",\"url\": \"http://actjira.atlassian.net\"}" I tried this. But not working
Ok, is EX1 a valid project key in your system? What error message / response are you getting to this call?
I try to create new project with this key. I not getting any error message or response But when i debug my code below mentioned code executing using (var reqStream = request.GetRequestStream()) using (StreamWriter writer1 = new StreamWriter(reqStream)) { writer1.Write(data); }
There's always a response of some sort, unless the call works, so my best guess is that your code is not actually performing the call, or it's not processing the response. I can't help you with your .net code, I don't use it.
Are you able to say what are the possibility of non performing call?
Start by ignoring your code. On a command line, try a simple "curl" call to create the project (have a look at the example code in the docs for doing that). That will always give you a response of some sort. If it fails, you'll get an error telling you why. If it works, then you know your code is not performing the call.
If you're on Server, check Admin -> General Settings -> Remote API is enabled (it is on by default) If you're on Cloud, then it's enabled.
Toady i getting error message from Jira when i try to add project. That messge i giving below StatusCode: MethodNotAllowed, Content-Type: text/html;charset=UTF-8, Content-Length: 0 whats meaning of this?
Please make sure REST API option is enabled in JIRA.
