Add searching to custom field
Dwayne Gravitt May 7, 2014
How do I add searching to an exiting multi select custom field in Version 5.2? When I click edit, I dont have the option to add search template. When I create a new multi select custom field the option for search template is there.
Nic Brough -Adaptavist-
May 7, 2014
You shouldn't have any need to think about coding!
What do you actually get when you click on the cog to the right of the custom field and select Edit?
Could you list off the fields you are offered?
HA, I was trying to configure instead of edit!! Now, do i have to reindex for it to pick it up, or will it start eventually?
NM, its showing up now. Thanks for your help.
May 8, 2014
You will need to reindex if you have data in the field already. But it's only searches that won't really work until you reindex.
Is there any way to do this in the GUI? I am new to Jira and haven't got into "coding" yet.
Umair Haroon
May 7, 2014
You might need to do this via code which Installed the multiselect custom field.
Register now
