I have the following ScriptRunner behaviour script for our "Required Reviewers" multiuser custom field:
import com.atlassian.jira.ComponentManager
import com.atlassian.jira.user.UserPropertyManager
import com.atlassian.jira.issue.IssueManager
class SetRequiredReviewers extends com.onresolve.jira.groovy.user.FieldBehaviours
def run()
IssueManager issueManager = ComponentAccessor.getIssueManager();
def mutableIssue = issueManager.getIssueObject(underlyingIssue.id)
def groupManager = ComponentAccessor.getGroupManager()
List<ApplicationUser> reviewMembers = groupManager.getUsersInGroup("Review Board Member")
def reqRevField = customFieldManager.getCustomFieldObjectByName("Required Reviewers")
mutableIssue.setCustomFieldValue(reqRevField, reviewMembers)
However, it never populates, even though if I do some log debug statements, the users I currently have in the Review Board Member group are being found. There's no errors, either.
I also tried adding just a list of user names, but that didn't work, either.
What am I doing wrong here?
Try like this
def run()
def user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser();
ComponentAccessor.getIssueManager().updateIssue(user, mutableIssue, EventDispatchOption.ISSUE_UPDATED, false)
Thanks for the response!
I'm trying to populate the field on screen launch. Basically pre-populate the field for the user with default users pulled from the Review Board Member group. So while that works, I have to go back into that state transition to see the update, and then continue with the flow.
If there was a way to set the default users in a multiuser select field to a group, instead of having to add individual users as default, that would be ideal. Unfortunately I don't see a way to do that so I was using a behaviour. Is there a better way?
You are not using behaviours the right way. You should set values with setFormValue method.
https://scriptrunner.adaptavist.com/latest/jira/behaviours-api-quickref.html
I had tried that previously (all my other behaviors use the normal api and work fine), but all I get in the multiuser field is [object Object] when call reqField.setFormValue(reviewMembers).
So perhaps I'm just not passing the correct list of values. I'll mess around with it more. Thanks!
Ah yup that was my problem. I was passing in the list of ApplicationUser and apparently via a Behaviour you have to pass in an array of user name Strings. Got it! THank you for the help.
I am glad you solved the problem
@Jason Adam Can you share your script for updating the multi user select field. I can't seem to get this to work.
def usersField = ComponentAccessor.customFieldManager.customFieldObjects.findByName("User(s)")
String[] users = ["boisvers"]
usersField.setFormValue(users)
Figured it out, you have to use getFieldByName for service desk/management forms:
def usersField = getFieldByName("User(s)")
usersField.setFormValue(["boisvers"])
Hi Jason,
could you please tell me how exactly did you solve this problem?
I am trying to achieve a similar thing. I want to pre populate a mult userpicker field with values from the same field of the parent issue. I tried a lot of approaches with arrays but just couldn't get it to work...
Here is my script so far:
import com.atlassian.jira.user.util.UserManager
def UserManager = ComponentAccessor.getUserManager()
def parent = getFieldById("parentIssueId")
Long parentIssueId = parent.getFormValue() as Long
def issueManager = ComponentAccessor.getIssueManager()
def parentIssue = issueManager.getIssueObject(parentIssueId)
//Parent
def teilnehmerField = customFieldManager.getCustomFieldObject(11400)
def parentValue = parentIssue.getCustomFieldValue(teilnehmerField).toString()
//Child
def teilnehmer = getFieldById("customfield_11400")
teilnehmer.setFormValue(parentValue)
I am only getting "[hessling(hessling)" pre populated in the multi user picker field, but not the usernames...
Many thanks in advance
Daphnis
